INEOS OIL FILTER PART NUMBERS AND REVIEW - B57 & B58 MOTOR
Mann probably/may make the filter for BMW, hence they look identical. They just have different packaging.
These relationships are not always transparent, but Mann has been associated with BMW over many years. Car makers normally source filters from OEM filter companies, they do not make the filters themselves.
My Ineos Grenadier Diesel was delivered as standard with a BMW oil filter No. 7826800-01 - Made in Tunisia. This filter also has the number UFI - 25.252.00 (Universal Filter Italiana S.p.A.). printed on the housing .
When you purchased the above BMW filter, it came in a BMW box with the number 1142 7 826 799.
I also now bought an UFI filter with the number 25.252.00 but without BMW imprint. This filter is also made in Tunisia. Both filters have identical dimensions and the same number ( 50 ) and depth (approx. 10.2 mm) of the filter paper ribs. To me both filters look absolutely identical, except the UFI filter is significantly cheaper. I think both filters are made by UFI North Africa in Tunis/Tunisia
I just found this while searching (unsuccessfully) for the UFI filter to buy. It gives filtering figures of 85% to 22 micron.
Not sure how reliable the source is, but it looks official
Add another to the list (for sure for Petrol so im assuming its also for the Diesel)
WIX WL10342
"Laboratory Test Performance per ISO 454812: dirt-holding capacity of 18 grams and 99% efficient at 23 microns (a human hair is roughly 70 microns in diameter)"
Thank you gents for all the info and work you put into this. From the lusted info the wix seem to be the better option but not for extended service intervals. Dont care im still in toyota land of yesteryear oil service every 7500km. Air-filter every 15000km.
Till looking for a way to upgrade the air filter im not sold on the factory fitted one.
Resurrecting old thread - Turner Motorsports shipped me a different filter than listed above, but cross-references it to the numbers supplied here. It's a BMW filter, #11-42-5-B4C-845. Researching with BMW, sounds like it replaces the part number ending in 799. Putting in later today, we'll find if that's true. :)
Some days I miss my big block, square body suburban.
Everything went fine, the oil filter is identical to old part number. Surprisingly easy to do an oil change on the Grenadier, reminds of doing the CJ7 oil. Mostly, the problem is I invariably spill some oil. Doh!
I hate hate hate the fact that it doesn't have a dipstick though. I guess I don't care with the other 2 BMWs we have because they just go in for service (I don't have a lift, not crawling under the M2).
