Oil Change Diesel Grenadier.
Riverswale
1:03 PM
Richmondshire
After some advice re engine oil change. I am thinking of carrying out an interim engine oil change on my diesel Grenadier. Ineos recommend a SAE 20w 30 fully synthetic lub oil. I have ten litres of Mobil 1 SAE 0w - 40. Am I right in thinking that this oil exceeds the specification recommended by Ineos. Does anyone think I should not use this oil. I believe in using the best engine oil in order to preserve engine life. Let me know your views.
Thanks
I use 5w40. It also exceeds the spec. It doesn't really get cold enough here to justify the '0'.
Manol make a 0w40 that does meet the spec if you want to use that..
My understanding is that the oil has to be low ash and DPF compatible so even if the viscosity is the same the oil may not be suitable.
That is correct. It has to be an ultra low SAPS oil.
