What about the Red Arc brake controller? I plan to install one of the two I have sitting around. Now that there wiring diagram has been released, 7700 lbs, here I come lol
How do you like the Oru Kayak?Well 1st trial-run went smoothly pulling the camper this weekend. One thing to note is that I couldn't use my portable CURT trailer break controller. When you hook it up you get an error message about the trailer brake lights and the turn signals don't work. When you hook it up directly into the 7 pin connector everything works just fine. Long story short "no trailer brakes or signals" which means we will chew-up the Grenadiers brake pads quickly if when tow. "Luckily my Mini toy-haler only weighs about 3,500 lbs fully loaded". Surely after-market will make something compatible with our Grenadiers 7 pin. Other than this Family camping trip went great. View attachment 7848804
They are great on flat/calm water and easy to transport/carry about anywhere. Anything more serious i would use my Jackson kayak.How do you like the Oru Kayak?
Just started to look at these so this might be my best option at this point. I was just hoping I could have used my $300 portable option from CURT instead of spending another $200 + for a vehicle specific one.What about the Red Arc brake controller? I plan to install one of the two I have sitting around. Now that there wiring diagram has been released, 7700 lbs, here I come lol
Recently finished install of a Redarc controller. Link to the installWhat about the Red Arc brake controller?
Ours is a 23’, but we’re planning to head out this weekend.I can't believe there is no one here in NA hooking up a std 25' 7,000lb load capacity trailer to a Grenadier yet, and showing it here.
Does your boat trailer have surge brakes or electric brakes... Never owned or pulled a boat, so I am not familiar. Surge brakes would not require a separate brake controller.I guess I’m just confused. Used to tow our 6-7000lb wake boat routinely with our new Defender just fine. The LR didn’t have a separate brake controller and the electronic brakes seemed to function just fine on the trailer. Is this not the case with the Grenadier?
This is our rolling base camp.Recently finished install of a Redarc controller. Link to the install
Does it feel like the trailer brakes kick in a moment after the vehicle starts slowing? If so, sounds like surge brakes, as I don't think the new Defenders have built-in brake controllers. The vast majority of boat trailers use surge brakes from what I remember (specifically so that they can be towed easily by a wide array of vehicles and you don't need a brake controller)As bad as this sounds I just know that the trailer plugs right into the 7 pin harness and works…
Sorry @BillLumberg only just catching up with this thread. Call your dealer and ask for them to do the install and software update, that’s my only suggestion. They have been given the go ahead to perform this work. The scheduling and implementation is totally in their court. I think this is a situation where persistence will get things going.Stu_Barnes Can you provide anything directly from Inoes that I can give to my dealer so they will install the hitch?
Yes, every should be in hand ready to installThe part (the hitch itself) wasn't removed at the dealer, it was removed at the port; the dealers then held on to those parts for reinstallation later (now).
They shouldn't have to order anything...
When researching the New Defender, many were installing the Redarc brake controller...for an extra couple of hundred dollars I would gladly say yes to an OEM installed brake controller.Does it feel like the trailer brakes kick in a moment after the vehicle starts slowing? If so, sounds like surge brakes, as I don't think the new Defenders have built-in brake controllers. The vast majority of boat trailers use surge brakes from what I remember (specifically so that they can be towed easily by a wide array of vehicles and you don't need a brake controller)
If that's the case, it'll work exactly the same with the Grenadier
Dream pair! Only missing the stream!Recently finished install of a Redarc controller. Link to the install
That’s good news!Sierra INEOS in Southern California has begun calling owners to install the tow package and software update. I took delivery in December and just got the tow package installed this week.
After the software update, I no longer have the lane departure display next to the speedometer. The audible warning does chirp if I change lanes without using the blinker.
Also! The ADAS speed warning is gone! No speed limit sign on the speedometer and no over speed limit clicking at all. The ADAS menu which was in the Vehicle Functions menu is gone. My FAV button was set to the ADAS settings page before. Now when I hit FAV, I still get to the ADAS menu, but there does not appear to be any way to navigate to the ADAS menu through the main menu.
There’s a new line in the Vehicle Functions menu called Speed Warning which defaulted to Off.
Has anyone else noticed this after tow package install? How do I get the software version number?
I had the tow hitch and software update done a few days ago and am still getting the speed warning sound and still have to to go to Favorites to turn of the warning. I didn't notice the lane departure icon missing, I'll spend some time in it today to see if they really did the software update because I didn't notice any of the changes you mentioned.Sierra INEOS in Southern California has begun calling owners to install the tow package and software update. I took delivery in December and just got the tow package installed this week.
