Rain water pooling under drivers door seal.
Barttraeger
2:36 AM
Munich
Does anyone else have the issue that rain water collects under the seal of the driver’s door so that a mini flood onto the road happens when the door gets opened? As far as I an see there is no water inside the vehicle so it is obviously outside the sealed area. Not a major issue and I have got used to standing away from the vehicle whilst opening that door after rain.
Yes, exactly that but on the passenger side. Any ideas what causes this.
Upvote 0
Exactly the same problem but on the passenger side.
Upvote 0
Exactly the same problem as Barrtraeger, but on the passenger side.
"Does anyone else have the issue that rain water collects under the seal of the driver’s door so that a mini flood onto the road happens when the door gets opened? As far as I an see there is no water inside the vehicle so it is obviously outside the sealed area".
Upvote 0
Have a look at the “wet feet” thread 😀
And no, you are not alone!
For a quick and dirty (or more fast and economic) solution you buy such a hose:
and just push it in the gap of the doors seal. This will make it be pressed tighter to the inner wall.
that’s it.
The other solution is to cut a hole into the lower part of the outer seal.
I would not recommend this if not your dealer tells you to do so till the new seals arrive.
Upvote 0
Quite a few have this issue, and new door seals will be required. Mine pools on both passenger and driver sides... for now, I have a piece of 6/o-d water pipe from an ice maker that I will temporarily install tomorrow as per the other treads found solution.
Upvote 0
Mine does exactly that - Ineos knows about it but so far no solution
Upvote 0
I stuck some 5mm air line hose in the gaps and it's made zero difference. Might be lacking in girth! Will try a fatter hose.
Upvote 0
Yes we also have this issue! Does anyone know how to fix it ?
Upvote 0
i had the same issue with my Volvo XC60 (MY 2019) on both sides, it "vanished" after one year = first inspection at the car dealer. until then: open the door very slowly so that it becomes a trickle rather than a waterfall. 😇
Upvote 0
I have this same issue. Passengercdoor was adjusted as it was always a double or triple slam. Now single slam to close but pools rainwater or car wash water between the seals sigh.
Upvote 0
