Roof outlet fuses
Yes, happy to hear from either you or Krabby offline, surprised you raised the topic at all, as I had taken the "joint IP" mentioned by @Tomdoc to be a light hearted reference to @Jean Mercier and myself.
Mate
I don't want you reposting any pictures of my shed or using them to try to pick up girls at the Gympie muster.
Them girls like a man with a big shed.
Actually the pictures came from Widespan sheds so maybe i shouldn't have posted them on here.
I once went to the all you can eat Pizza Hut at Gympie on the way to Fraser Island. Now that was an eye opener 😳
All, anyone has any idea if it is risky to swap the EXT 2 roof fuse out for a 40 amps? I’m looking at a Lazer roof light bar and it draws 25.3 amps @ 14.4 volts so I’m thinking that it’s a bit too close in terms of draw. The cabling should be OK. Not so sure about the relay and the 25 amp fuse. Any ideas and insights are very much appreciated !!
Mate
Have you used pics of your shed to pick up girls? Have you pics of the girls? Can you please post the pics of the girls on this forum 👍
I am confused as to the nature of some comments above. I was under the naïve misapprehension that we try to help each other freely here and are very good at it - my comment on "joint IP" was a light-hearted reference indeed. Anyway - onwards and upwards chaps.
Spot on - the whole reason @Stu_Barnes created this forum is for that very reason. The comradery, entertainment, and friendships are wonderful side effects, but my understanding is we're here to help one another. Re-posting an image from another member is not stealing and, while attribution is nice, unless someone is claiming the work of another to be his own, there's no copywriting infringement. Lots of images here are not our own but many do not claim that they are; and TBH, people who have added any images that they did not take themselves have no business calling anyone out (that certainly includes me).
I'm really not sure why you felt the need to wade in again.
And it seems the pair of you can post repeatedly in the public forum but when challenged on the factual content of those postings, the issue has to be taken offline:
"Please contact the forum admin account for clarification."
So to summarise, someone made a lighthearted common on joint IP and the forum owner misinterpreted it and posted "correct" and linked to forum rules that make reference to copyright explicitly NOT being joint.
If asking another to “remove” your images was lighthearted that went over my head. I responded to most of your points
HERE
Hey @gkhaldi did you get an answer to this? I picked up a light bar with the same power requirements, the Triple-R Linear 48” Elite, which draws 25.3 amps at 14.4 volts for total of 364 watts.
I’m concerned about both the wiring capacity (what gauge wiring did Ineos use), as well as the fuse and relay. Particularly as this leaves 0 headroom at 25 amps.
