General Oil Change Procedure & Specs
Singletracker
5:38 PM
AZ
Summary
I spent quite a bit of time researching what oil to use and how to conduct my first oil change on my B58 gas/petrol Grenadier. I thought I'd document and post up my findings, references and hopefully save others time so they can spend more time exploring, four wheeling or time with their loved ones. I'll reference the Dickin' Around Outdoors Ineos video for visual learners like myself. Feel free to debate anything since I've picked and choose everything I did from various sources on this forum and the manual itself.
Tools for Oil Filter Procedure
  1. 1/2" ratchet
  2. 32 mm shallow socket
  3. 3" 1/2" ratchet extension
  4. 1/2" ratchet torque wrench
Tools for Oil Plug Procedure
  1. 3/8 ratchet
  2. 17 mm shallow socket
  3. 3" 3/8" ratchet extension
  4. 3/8" ratchet torque wrench
Specs
  1. Oil Plug spec: 25nm or 18.5 ft/lbs
  2. Oil Filter Housing spec: 25nm or 18.5 ft/lbs
  3. Oil Capacity added: One full 5L jug + 2000cc of Top Tec 6600 for a total of 7.38 Quarts
Oil & Filter
  1. LiquiMoly Top Tec 6600 SAE 0w-20 -i bought 2 5 liter jugs. This is spec'd as BMW Longlife-17 FE+
  2. BMW OEM 11427826799
Procedure
  1. Warm up car for a few minutes, park your Grenadier, set the parking break and chock your tires. Open hood and set the hood rod at the maintenance setting -
    View: https://youtu.be/LzTYyVVvp-s?si=yvzS7XC4cq_VS2QJ&t=214
  2. Remove BMW/Grenadier engine cover -
    View: https://youtu.be/LzTYyVVvp-s?si=kPWrQv5oDYh2ZCa5&t=292
  3. Locate oil drain plug -
    View: https://youtu.be/LzTYyVVvp-s?si=ttBu9mnv2XXUTn1D&t=334
  4. Remove valve cover oil cap using 32mm socket -
    View: https://youtu.be/LzTYyVVvp-s?si=2ahzoSd303cfP2aD&t=365
  5. Remove oil drain plug using 17mm socket -
    View: https://youtu.be/LzTYyVVvp-s?si=BY8jY27mkTPzi50d&t=381
  6. Locate oil filter housing, loosen housing and remove the housing and oil filter. I didn't need the swivel joint since a 3" extension and socket has enough clearance to loosen - https://youtu.be/LzTYyVVvp-s?si=6UddwVS_Jsagh-5i&t=422
  7. Replace filter element and re-install housing with 32mm socket at 18.5 ft/lb or 25nm - https://youtu.be/LzTYyVVvp-s?si=838siB-PIfmf3aeZ&t=677
  8. Reinstall plug with new gasket using 17mm socket at 18.5 ft/lb or 25nm - https://youtu.be/LzTYyVVvp-s?si=QrLkrb4Q_cdWx2Gi&t=799
  9. Add oil (I needed just under 7.5 quarts)
  10. Reinstall BMW/Grenadier engine cover with a nice procedure here - https://youtu.be/LzTYyVVvp-s?si=Cql9eYhVQPTgbw3l&t=908
  11. Bring engine up to temp, set in park and using the oil check procedure in the infotainment system.
  12. Enjoy the truck and change follow procedure all over again in 5k.
I would swap step 10 and 11 around. Start and have a look for leaks before fitting the cover and while the cover is off have a look around and make sure everything looks secure and not rubbing. Even the inexperienced DIYer can pick up on things that don't look right.
I went Votex. Much more compact than Valvomax, Fumoto, etc... and also stainless. Has a magnet at the end and a different valve mechanism than the others. Made in USA too!
Having done the oil today, one thing that annoyed me was the crappy plastic oil cap. If your socket slips while wrenching the filter housing open or closed, it’ll begin to mar easily.
Looked around for something better and found this slick billet cap for the B58. Going to slap this thing in next oil change and make my life ever slightly easier.
Unfortunately, Votex either doesn't have a magnet on the end of this drain plug, or they don't have them currently because of supply chain issues. Just called and asked, they're trying to source magnets from multiple sources, but all magnets they use via whatever source all come from China. Was told check back in 45 days or later. Still, it looks like a really good drain plug without the magnet too.
Ya, you're right. Mine didn't end up with a magnet. They sell the magnetic drain plugs, but not valves. I got the valve and while no magnet, it's a really nice little unit.
For oil and magnets, you could get the Burger Tuning oil filter housing: https://burgertuning.com/products/bms-billet-oil-filter-cap-b58-bmw-toyota-engines
