Hello folks,
In our history, we have not done detailed build threads. But I feel that this vehicle warrants the effort from the team. We will most likely trim comments to items that are relevant to our build as a source for other users to get detailed information about what we do and why. Less about wheels tires, suspension etc as that is not our area of expertise. We will tell you what we did with other vendors, how and why. But we will probably not answer a lot of questions about those areas of the build.
Thank you and we are very excited to build out our new Grenadier.
Once we get it wrapped up, we will definitely be showing it off. It will be at Expo Flagstaff for its maiden show. But if you are in the Grand Junction area in mid to late April, stop by and it will be in progress.
Thank you. When you do, ask Mule to contact us so that we can make sure on our end that the entire kit ships together at the same time.
We got our Silenus roof conversion done a few weeks ago and I can tell you it is amazing! We also have the complete Goose Gear plate system on order and are awaiting its arrival. Really looking forward to see how they design the build out.IMG_3985.jpeg
Looks amazing! We expect to get ours installed right after Expo SoCal and then the design process begins.
What is the status of your Alucab conversion and the storage build out? I will be in the Grand Junction area later this month, maybe I could stop by to check it out.
I will be at Tiny Rig Co in California next week cutting the roof off of the rig. Finally....but never too late. Unfortunately, due to the timing, we will not be able to get into the interior design until after Expo West. I am hopeful that we will have the interior completed for Expo PNW or Expo Mountain West in Colorado.
Understood and thanks for the update. I live on the Front Range and will plan to see the completed setup at Expo Mountain West in Loveland.
Headed straight to Moab after the roof conversion Brian?
I’ve known Brian for a while, but I just wanted to drop a note here on how much I’m enjoying this Goose Gear combo. Not only did I end up with more storage, but I can actually put larger items in the back because it sits higher than the rear seats when folded.
The fridge is also the perfect size! I use it all the time, with none of the size compromise of a chest style fridge.
The fridge is also the perfect size! I use it all the time, with none of the size compromise of a chest style fridge.View attachment 7894866
Which kit did you get? Their website is confusing..
What do you meant by “it sits higher than the seat, when folded”?
