Goose Gear Roof Conversion Interior
Fantastic setup and a good alternative to the system from OK4wd/GP Factor.
Please add individual photos of all the left side storage compartments opened up.
Would a petrol or diesel heater from Webasto fit in the small area forward of the Jerry can compartment? Petrol would be ideal with the fuel line plumbed to either the OEM tank or a Long Range America aux tank. View attachment 7909066
I believe so. The other option is in the footwell space behind the front seat which is more likely to work out. Plus we get direct access for heater exhaust venting outside the vehicle. At this time, that is my plan. The GP kit is pretty dialed, just a different style.
I assume an enclosure would be created for the heater that attaches in front of the electrical box in the foot well. Direct venting through the floor in that area makes sense and the fuel line could exit through the floor as well. Petrol is definitely preferred as it would negate the need to carry additional fuel in the form of diesel or propane in the case of a Truma propane heater.
Agreed, if we do a heater it will definitely run off of our LRA tank.
Hello all, here is the breakdown of how we will be offering the interior kits.
We will offer the kits in packages,
1. Venture Series Roof Conversion Interior (RCI) RH Drawer Module, LH Sink Module and LH Water Module. $10,000.00. This kit will ship bare, without water or electrical options. It will also not have any cutouts in the panels for electrical or water systems.
2. Venture Series Rear Plate and Second Row Seat Delete, RH Drawer Module, LH Sink Module and LH Water Module. $12,000.00. This kit will ship bare, without water or electrical options. It will also not have any cutouts in the panels for electrical or water systems.
3. Venture Series Roof Conversion Interior (RCI) RH Drawer Module, LH Sink Module and LH Water Module with Water and Power Systems. $15,000.00.
4. Venture Series Rear Plate and Second Row Seat Delete, RH Drawer Module, LH Sink Module and LH Water Module with Water and Power Systems. $17,000.00
5. Optional, Shower Kit, includes window panel, shower control and National Luna Light. $950.00 - Requires Gull Wing Window by Others
Introductory Pricing is listed above; we expect the pricing to increase by around $2,000.00 per packaged system in the near future. We do not have a specific date for the increase to the regular price.
For the first 4 systems that are sold, we will require the purchaser to come to our shop for installation, you can certainly purchase it from your favorite dealer, and we encourage you to do so, but the installation will have to be here. The reason behind this is that we want to ensure that every system we produce fits every Grenadier flawlessly. Our design, like our other kits, has some adjustability and tolerance built in and we do not expect any issues, but before we ship someone a kit, we want to be 100% confident that it will remain a truly bolt in system with minimal tools and no modifications. Even though the Grenadier is one of the most consistent vehicles I have ever worked on. It does still have build tolerances from the factory that stack up and can create issues.
Water and Power systems will include:
1. Pair of high power 100-watt USB C Chargers
2. Blue Sea Weatherdeck 7 Switch Panel with Integrated Circuit Breakers
3. Pair of Egis Relays for Master Power Switch and Water Heater
4. Single Baja Designs Rock Light for Cabinet Interior Top Shelf
5. Connections for Optional Single National Luna Exterior Light for Shower Kit
6. Custom built wire harness by Blaze Offroad, SAE Grade Connections using premium GXL wire where possible and premium connectors. Not knock off terminals or connectors.
7. 50-amp Fused Power supply cable kit from factory second battery location to LH Sink Module interior with 50-amp Anderson Connector - 6 Gauge Main Power
8. Ambassador Marine Sink
9. Scandvik Water Faucet
10. Whale Marine Hot Water Heater 12v 3 Gallon
11. Whale Marine Water Pump with Expansion Tank 12v
12. Whale Marine Water Fittings and Piping as Possible - Some items require flexible tubing.
13. This kit will also include two custom mounting plates for the water heater and water pump for a 100% bolt on installation.
Optional Shower Panel will include:
1. Custom cut Bamboo mounting panel with hardware
2. Scandvik Shower Mixer with On/Off Trigger Handle
3. National Luna LED Light
What to do if you already have the Goose Gear Grenadier Rear Plate and or Second Row Delete.
1. If you have the rear plate, you can keep it, and everything will work just fine. The redesigned plate has a couple additional mounting points, and I have removed excess mounting locations as they are not needed. If you still want to replace your existing plate with a newer version the cost would be $400.00 with the purchase of an RCI interior kit.
2. If you have the second row delete, there are two options.
a. You can keep the existing second row delete, and the system will work just fine.​
b. If you purchase an RCI interior kit, we will give you the option to upgrade your second row delete for $500.00 and you can sell the old one on the used market for $800-$1,000 +/- fairly easily. If you choose this option, you will get a completely new second row delete with hardware. This is below my cost on this item, but we want you to have the option for the best possible build you can.​
3. This is a one-time offer and only applies to the original purchaser of a seat delete or second row delete.
Please tell me you are bringing this to Moab. I would love to see this in person! Great job! This is all starting to remind me of Westfalia conversions for the VW Bus.
Change of plans, we will be attending the Oktoberfest in Moab and will have the Grenadier on display.
Wish we could be there for this event. It would have been great to really look over the build and open all the drawers/cabinets and see what kind of access exists to the lower left hand side storage spaces (where the bottle jack and inverter used to be). Any pictures you all can share would be great!
We will be getting more interior shots inside the modules later next week and will gladly share. For the jack space, it is accessible, but very limited access due to the shelves, water heater etc. Our unit has the factory inverter and we did not remove it.
Thank you…good to know.
We’re in talks with the folks at @GPFACTOR to figure out a way for their heater system to integrate into our cabinets. It will be coming and we’re working on modifying the cabinets to accept it now so that if you order our roof conversion interior kit now it will be compatible when the heater kit comes to market.
The heater kits will most likely be available early next year. They are still in development at GP but very close.
This is great news. Thanks for the update.
Any additional photos of the interior spaces and any measurements such as the long drawer interior width (where the pots and pans are)?
I saw the GP Factor diesel heater at Overland Expo East, it looks to be a beautiful solution.
I saw the GP Factor diesel heater at Overland Expo East, it looks to be a beautiful solution. View attachment 7911027View attachment 7911028
Looks great, very OEM like. In a conversation at Expo West with Rin from OK4wd he told me there will also be a ladder that contours around the two external black enclosures so you can retain the functionality of the original factory ladder if desired.
Even better with the ladder 👌🏼
When I design an interior space, the focus is always on living space and comfort. For my rear drawer, there are no tools, no recovery gear, just kitchen items (AND COFFEE). Tools, recovery gear etc needs a home, but in our interior design, those items (typically very heavy items) are stored in the second row footwells on both sides of the truck. I believe that you should focus on the items you will use every day, food and food prep are the most common items in every truck we have built in the past 11 years. After that, we focus on camp comfort, chairs, firepits, blankets etc. Those items are stored in our 81-liter AluBox which fits perfectly between the kitchen and drawer module. This also serves as your step to get in and out of the truck. It can also function as a great camp table.
I am going to break this down by section:
RH Drawer Module - The drawer has a stair step design and gets wider as it goes up. See photos.
Drawer Interior at top 11-7/8"w x 37-1/2"l x 3"h (300x950x76)
Drawer Interior at bottom 10-7/8"w x 37-1/2" x 5-1/4"h (275x950x130)
Overall height of the drawer is 8-1/4" high including the low and top section. (210mm)
These are the contents of our kitchen drawer.
Photo of the drawer empty
Section below the drawer fits two Step22 Stingray Flat Boxes perfectly (maybe it is because the owner of Step22 is a good friend, who knows?) The end molle panel where we have the little Blue Ridge Overland Gear Molle bag is optional, it is included in the product, but you can remove it and use that as an end loading space as well. Such as for the long-folded camp chairs. Tent poles etc. The Space below is 38"l x 9-1/2"h x 13-1/2"w (965x240x340) but keep in mind that the wheel well is behind there as well so some of that space is blocked by the factory plastic around the wheel well.
Lift Hinge doors on the top of the module utilize user adjustable friction hinges. We keep them a bit tight so that the doors will stay open even when opened at an angle. The lift doors are to allow access to the drawer contents with the rear vehicle doors closed.
There is a small storage space between the drawer module and the vehicle exterior. This area is accessed with a flip up door and is great for longer items, We store our Force Protector Gear Awning poles and the AluCab Tent Rain Fly bars in this space as they slide in from the front quite easily. The space is approximately 4" wide (100mm) at the wide end and 2-1/2" (65mm) wide at the front narrower end. Height is 10" (255mm) above the wheel well and 14" (355mm) at the rear D pillar. This space utilizes the same soft close quick disconnect hinges as the doors in the Sink module.
Awesome! This may be a good idea fairy thing but have you considered using a footwell water tank like the ones commonly seen in Defender builds? This would then allow an upright fridge where the current water module is.
