Goose Gear Roof Conversion Interior
Fantastic setup and a good alternative to the system from OK4wd/GP Factor.
Please add individual photos of all the left side storage compartments opened up.
Would a petrol or diesel heater from Webasto fit in the small area forward of the Jerry can compartment? Petrol would be ideal with the fuel line plumbed to either the OEM tank or a Long Range America aux tank. View attachment 7909066
I believe so. The other option is in the footwell space behind the front seat which is more likely to work out. Plus we get direct access for heater exhaust venting outside the vehicle. At this time, that is my plan. The GP kit is pretty dialed, just a different style.
I assume an enclosure would be created for the heater that attaches in front of the electrical box in the foot well. Direct venting through the floor in that area makes sense and the fuel line could exit through the floor as well. Petrol is definitely preferred as it would negate the need to carry additional fuel in the form of diesel or propane in the case of a Truma propane heater.
Agreed, if we do a heater it will definitely run off of our LRA tank.
Hello all, here is the breakdown of how we will be offering the interior kits.
We will offer the kits in packages,
1. Venture Series Roof Conversion Interior (RCI) RH Drawer Module, LH Sink Module and LH Water Module. $10,000.00. This kit will ship bare, without water or electrical options. It will also not have any cutouts in the panels for electrical or water systems.
2. Venture Series Rear Plate and Second Row Seat Delete, RH Drawer Module, LH Sink Module and LH Water Module. $12,000.00. This kit will ship bare, without water or electrical options. It will also not have any cutouts in the panels for electrical or water systems.
3. Venture Series Roof Conversion Interior (RCI) RH Drawer Module, LH Sink Module and LH Water Module with Water and Power Systems. $15,000.00.
4. Venture Series Rear Plate and Second Row Seat Delete, RH Drawer Module, LH Sink Module and LH Water Module with Water and Power Systems. $17,000.00
5. Optional, Shower Kit, includes window panel, shower control and National Luna Light. $950.00 - Requires Gull Wing Window by Others
Introductory Pricing is listed above; we expect the pricing to increase by around $2,000.00 per packaged system in the near future. We do not have a specific date for the increase to the regular price.
For the first 4 systems that are sold, we will require the purchaser to come to our shop for installation, you can certainly purchase it from your favorite dealer, and we encourage you to do so, but the installation will have to be here. The reason behind this is that we want to ensure that every system we produce fits every Grenadier flawlessly. Our design, like our other kits, has some adjustability and tolerance built in and we do not expect any issues, but before we ship someone a kit, we want to be 100% confident that it will remain a truly bolt in system with minimal tools and no modifications. Even though the Grenadier is one of the most consistent vehicles I have ever worked on. It does still have build tolerances from the factory that stack up and can create issues.
Water and Power systems will include:
1. Pair of high power 100-watt USB C Chargers
2. Blue Sea Weatherdeck 7 Switch Panel with Integrated Circuit Breakers
3. Pair of Egis Relays for Master Power Switch and Water Heater
4. Single Baja Designs Rock Light for Cabinet Interior Top Shelf
5. Connections for Optional Single National Luna Exterior Light for Shower Kit
6. Custom built wire harness by Blaze Offroad, SAE Grade Connections using premium GXL wire where possible and premium connectors. Not knock off terminals or connectors.
7. 50-amp Fused Power supply cable kit from factory second battery location to LH Sink Module interior with 50-amp Anderson Connector - 6 Gauge Main Power
8. Ambassador Marine Sink
9. Scandvik Water Faucet
10. Whale Marine Hot Water Heater 12v 3 Gallon
11. Whale Marine Water Pump with Expansion Tank 12v
12. Whale Marine Water Fittings and Piping as Possible - Some items require flexible tubing.
13. This kit will also include two custom mounting plates for the water heater and water pump for a 100% bolt on installation.
Optional Shower Panel will include:
1. Custom cut Bamboo mounting panel with hardware
2. Scandvik Shower Mixer with On/Off Trigger Handle
3. National Luna LED Light
What to do if you already have the Goose Gear Grenadier Rear Plate and or Second Row Delete.
1. If you have the rear plate, you can keep it, and everything will work just fine. The redesigned plate has a couple additional mounting points, and I have removed excess mounting locations as they are not needed. If you still want to replace your existing plate with a newer version the cost would be $400.00 with the purchase of an RCI interior kit.
2. If you have the second row delete, there are two options.
a. You can keep the existing second row delete, and the system will work just fine.​
b. If you purchase an RCI interior kit, we will give you the option to upgrade your second row delete for $500.00 and you can sell the old one on the used market for $800-$1,000 +/- fairly easily. If you choose this option, you will get a completely new second row delete with hardware. This is below my cost on this item, but we want you to have the option for the best possible build you can.​
3. This is a one-time offer and only applies to the original purchaser of a seat delete or second row delete.
Please tell me you are bringing this to Moab. I would love to see this in person! Great job! This is all starting to remind me of Westfalia conversions for the VW Bus.
Change of plans, we will be attending the Oktoberfest in Moab and will have the Grenadier on display.
Latest posts
