Migs
great. thanks!
That looks really clean. Those brackets are genius. Which switch did you end up wiring them to? I assume the 25amp under hood ? Ext5?
Please keep me in mind if you are looking for testers.
Wow this is fantastic..sign me up for a pair of those brackets.I've attached a few more pics below showing:
- the various LED lights I experimented with (mostly PAR46 and a few pods)
- some install details
- the tight fit inside the grill light bucket
- the intensity of these new auxiliary lights compared to the headlights (hi beams)
I plan to install the next proto tomorrow then order a batch of brackets to send out. Thanks to everyone who volunteered to test them. I will DM people probably next week to figure out who is serious. I will ask you to source the lights yourself (~$80) and commit to installing the kit within a week of receipt. Your thoughtful feedback on the install process and any possible improvements is requested.
If anyone finds a good pod light candidate from a high-end light manufacturer, please message me. It would be great for people to have some choices.
@Stu_Barnes I wonder if you are following this. I think a bracket kit would be a great product for forum members, as it seems like there is a demand out there for a cost-effective upgrade path. Power(ful aux lights) to the people!
My choice would be spot, bypass dimmer control, and wired to my Switch Pros SP-9100I have a few questions:
For those considering the Dixi’s, are you going with spot, combo or fogs? Will you mount the toggle switch or wire directly to Ext5? Where are you planning on mounting the dimmer control?
i would aslo bypass dimmer control. and then somehow figure out a relay to utilize the existing on/off OEM switch.My choice would be spot, bypass dimmer control, and wired to my Switch Pros SP-9100
That is game plan as this thread the amps are to big, so we are connecting them to ext 5.Thats exactly what i would do. Find a way to use the switch in the high load panel as a switch for the extra headlights directly and bypass the offroad mode. Probably need to use a relay for it. I would also add in a second relay so they only come on with the high beams. I don't need dimmer.
This is a light that I did not look at closely until now. There is a lot to like about this option and I think it would mount well.@BenTN is it to late to throw the Baja Designs XL-r 80 into the mix?
@BenTN can you provide how much room/space there is around the Dixi light circumference and the plastic grill shroud? I am considering moving my vote from the Super Sevina to the Dixi but I want to be able to utilize the optional slip on covers and I am concerned that they will not clear the plastic grill light shroud. I am estimating the optional slip on covers that can be added will add an extra 2mm to the circumference or 4mm to the overall diameter of the light bezel. Also is the plastic grill shroud able to be ground to get more clearance? I do not have my Grenadier yet so I cannot get these dimensions my self. Your help would be appreciated.
