What's you're real world MPG (USA)
So I have had some interesting variations in my mileage over the course of the past year and a half of ownership. When I first got my Grenny (say the first 6 months) I would average somewhere around 14.5 MPG. Then when I mounted my 2 Jerry cans on the Bison Gear molle panel (drivers side rear window) my mileage dropped significantly. For the next several months I dropped into the high 12 MPG - low 13 MPG. This seemed awfully dramatic but I chalked it up to the weight and change in aerodynamics.
When winter hit I moved the Jerry Cans into the rear Cargo area. The mileage picked up a bit but more in the high 13 to low 14 MPG. as we moved out of winter and into mid spring I remounted the Jerry Cans to the molle panel. Interestingly enough my gas mileage has returned to the mid 14 MPG territory and in some cases into the 15 MPG.
*All surface road travels with roughly 80% highway at high speeds between 75-80 MPH
**I travel for work and the Grenny is my daily driver. I am in some remote areas (Upstate NY, VT, ME, NH) and there are times where gas stations are few and far between.
To add to that, I see no real significant difference whether I have my RTT on or not. And It's a Roam Vagabond, so not a little hard shell. I just chalk it up to these things being rolling bricks and enlarging the brick doesn't matter much.
That just isn't possible unless you were going downhill with a tailwind.
It was a 2 way trip on a UK motorway. I did a 2 way trip over the pennies on UK motorway, so up hill and down each way and it showed 30mpg average. That was around 200 miles.
Tyres are 40psi
I've always been good at getting high mpg.
It depends on how I drive it....when we drove from Colorado to Maine we got a whopping 9.6 mpg at times. This had a ton to do with my SPEED (85 to 90 MPH) for long stretches of time with a headwind. When I drove more conservatively around 75 to 80 mph I got about 12 mpg. Aside from the speed (speed kills...MPG...LOL), I get mostly 13 to 14 MPG on good days. Avg 12 to 13 mpg when doing the typical I-25 80 mph to 85 mph w/o being fully loaded to the gills.
In every vehicle I keep my fuel receipts and diligently keep accurate records. In ours, I find that 18.6 mpg shown on the computer works out to 15 mpg or thereabouts.
I do have a 3/4 Leitner rack with Maxtrax at the front of the rack as well as the rear side molle panels. I also have some beefy White Knuckle Off Road sliders that adds a bunch of weight.
Next potential mod for me will be skid plates that will add some additional weight.
Don’t think of skid plates as adding more weight; think of them as aerodynamically “cleaning up” the greasy side. Better mpg ensues!
You may have already discovered this information, but the difference is caused by the IG computer using Imperial Gallons for the calculation instead of US Gallons. Since the Imperial Gallon is larger, the denominator in the calculation is smaller and the MPG higher, than if you use US Gallons for the denominator.
The correction factor I use when I am want real time MPG from the computer is to multiply “displayed MPG X .833”. That gets you really close to real-world US MPG and accounts for the Imperial gal which appears to be baked into the trip computer. I have to assume IMP gals also calculate into “remaining range”- but I have not ever done the math there.
Modifying this seems to be low hanging fruit for some INEOS software engineer. …..While you’re at it give us a CHOICE between MPG(US), MPG(IMP) and L/100 km!
