Hopefully someone stateside can come up with a less cost prohibitive option. The stock unit is far from being robust. I can’t imagine that thing is built for the long haul.Invoice total with shipping was €1522 and then tariff was $700.
I replaced the stock unit because it kept popping out at the base despite the screws being tight. The D&G is secured with four M5x16 bolts at the flange.Hopefully someone stateside can come up with a less cost prohibitive option. The stock unit is far from being robust. I can’t imagine that thing is built for the long haul.
I have the 9005, too.I have the same issue with mine basically falling out of position. I decided to go the GrenX route, still trying to get around to installing the thing.
@grnamin which series Sy-Klone pre-cleaner did you go with?
I have a 9005 series (5” flange diameter) for sale if someone else is considering going this route?
Wow, they maybe changing their mind. They sent me packing back in 2023, when I asked.I came across this post on Facebook. It appears Safari Engineering are planning on producing a Snorkel and have a survey running for what type.
View attachment 7918420Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
Agreed, plus it will not have a sealed airbox. One reason the GrenX costs more.@TheDocAUS - Agreed. I’m not entirely convinced that is going to materialize any time soon:
I had the same issue. I could see there was tension on the RAI. I unbolted my RAI from the A-pillar brackets and then held it tight against the quarter panel. This created a 5-6mm gap between RAI and A-pillar brackets. So I made some spacers out of aluminium flat bar., and bought some 5mm longer bolts. The problem is now solved, even when travelling on the highway with my Syklone installed.I replaced the stock unit because it kept popping out at the base despite the screws being tight. The D&G is secured with four M5x16 bolts at the flange.
Brilliant. I am going to do this with 1/4" ABS plastic for a more stealth black finish.I had the same issue. I could see there was tension on the RAI. I unbolted my RAI from the A-pillar brackets and then held it tight against the quarter panel. This created a 5-6mm gap between RAI and A-pillar brackets. So I made some spacers out of aluminium flat bar., and bought some 5mm longer bolts. The problem is now solved, even when travelling on the highway with my Syklone installed.
A little progress, but still no commitment, but thanks for the effort and update.I emailed Safari Engineering, the screen shot attached is there reply.
The Red winch wasn't cheap either. but if these things save your carefully personalised vehicle, the cost is wearable if you keep it long term.GrenX remains the only option now, at least they have 3 choices. Granted not cheap, but neither is a new motor.
