Third party sealed snorkels for the IG and QM
Invoice total with shipping was €1522 and then tariff was $700.
Hopefully someone stateside can come up with a less cost prohibitive option. The stock unit is far from being robust. I can’t imagine that thing is built for the long haul.
I replaced the stock unit because it kept popping out at the base despite the screws being tight. The D&G is secured with four M5x16 bolts at the flange.
I have the same issue with mine basically falling out of position. I decided to go the GrenX route, still trying to get around to installing the thing.
@grnamin which series Sy-Klone pre-cleaner did you go with?
I have a 9005 series (5” flange diameter) for sale if someone else is considering going this route?
I have the 9005, too.
I came across this post on Facebook. It appears Safari Engineering are planning on producing a Snorkel and have a survey running for what type.
Wow, they maybe changing their mind. They sent me packing back in 2023, when I asked.
I went with a GrenX sealed snorkel and airbox and glad I did.
Speaking of GrenX - We’ve just gotten our replacement inlet and air filter from Rohan so we’re finally ready for the sealed airbox install later this week.
VICTORY! Our GrenX snorkel and sealed airbox system is now complete. Per earlier discussions we’ve opted for a Donaldson PowerCore G2 pod filter and it works wonderfully in our Petrol Grenadier ( no MAF issues / codes thrown etc. ). Definitely recommended.
The fit is insanely tight and a total PITA but it works.
I’ll probably adjust the heat shielding a bit more tomorrow…
We’ve adjusted the heat shielding so we have a slightly tighter fit around the aluminum airbox. The ball valve for the airbox is located here:
