Diesel Rear fuel filter on diesel – Australian spec INEOS
AU SPEC DIESEL – REAR FUEL FILTER IS THE ONE TO CHANGE
This AU Spec Diesel is fitted with two fuel filters. The water/fuel separator down near the fuel tank (passenger side rear wheel arch) and a second fuel filter up under the rear passenger (RHD vehicle).
Speaking to the Service Manager today at Purnell Adventure he said INEOS Australia recommended replacing the filter in the rear water/fuel separator. The front filter does not normally need to be changed (there must a need at some time?).
The rear fuel filter cost was AUD71.40 plus GST.
REAR FUEL FILTER PART NUMBER (water fuel separator on AU spec diesels)
Water Separator Filter Part No: GRA3E12019770
The rear INEOS water/fuel separator is slowly giving up its secrets. What the INEOS Configurator describes as the Diesel water separator.
It uses a “paper filter” (probably a Cellulose/Synthetic Blend) with INEOS Part No: GRA-3E12-019770. It is made in China. INEOS is the only name appearing on the packaging and both labels.
There are two other numbers on the box 11 00 1007 0321TZ and EI-00000119533. I could find nothing searching on all three numbers. I was hoping to find the OEM manufacturer. Fail.
The underlying label says filter expiry October 2024, the filter was made on 17 October 2022.
The fuel filter looks like this (the filter is in a plastic wrapper):
It comes with an O-ring for the filter case.
I spoke to the Service Manager about how to change the filter, apparently you need to disconnect both sets of wires (top and bottom of the filter case), disconnect the fuel lines in and out of the top of the filter case. Then undo the two bolts and take the casing off and change the filter. No simple task.
I still cannot get a decent image of the filter case but you see the two bolts on the top left of picture. I think the filter cap maybe the bottom of the case (what you see in the image below).
Thanks for your hard work @TheDocAUS !
Memo for off-road tool kit: include two water/fuel/brake hose clamps to enable fuel filter change.... ;)
When I was under the car today, I could not work out how to remove the fuel hoses, there must be some trick. I asked the Service Manager for INEOS' instructions. :ROFLMAO:
The Service Manager did get under the car and take me through the steps. Thank you Nathan at Purnell Adventure.
I will be asking for a written work instruction for this and replacing the serpentine belt when I take the car in next week to get some little warranty issues attended to. Bought the filter and Serpentine belt a couple for the spares kit, the day I got the car.
cheers
Steve
This is a picture of the rear fuel filter on the INEOS Australian spec diesel motor. EDIT: the diesel fuel water separator is standard in some countries and optional in others. When choosing a diesel motor if the option costs $0 dollars it is standard, if you have to pay it is optional. A little smaller than a Prevent 200 oil catch can (size comparison only). The type of plastic used was very similar to the material used in the Provent 200 Oil Catch Can.
The fuel in line and fuel out line are at the top of the filter and you cannot see them clearly in this image. It is hard place to get a decent photo.
The plug on the bottom is a AMPSEAL plug. I will tape up those exposed wires near the bottom of the image on the AMPSEAL plug. The ladder frame was red, the car was black.
Fuel filter located near rear wheel arch, passenger side (RHD car). You can only see it by getting under the car. You cannot see it by looking into the wheel arch over the tyre.
I could see any third party brand name on the filter case, but I could only see part of the case. White label has INEOS' name on it.
Second fuel filter location
Thanks to @DenisM we have the location of the second fuel filter: "Slightly to the rear of the mid-line of the rear LHS passenger door. It's a cylinder -at a (very) rough guess about 50mm in diameter and about 120-150mm in length, retained in a white coloured plastic "saddle" clip which is screwed to a "vertical" surface... It's visible from the RHS although the view is partially restricted by a/the ?muffler."
Image here (thanks to @MarkH for the link). I am thinking a guard for that filter might be a good idea ( I have emailed KAON asking for one):
img_20230807_150142-jpg.7822578
FUEL FILTER GUARD UNDER DEVELOPMENT
Stayed tuned because a guard for the fuel filter (see green arrow) is under development. Prototype already made and fitted.
The idea is to make the fuel filter and fuel line less vulnerable. At least one car has had the line detached from the filter offroad, probably by a branch, disabling the car.
EDIT: Guard now on sale, details here.
I’ve found the long cylindrical filter but I’m having a job find the one with the wires out the bottom. RHD vehicle. Would you be able to tell me where exactly this one is. It’s tough as I don’t have a ramp I’m having to slither under the vehicle up and down. Cheers
If the second filter is fitted to your car, look on the passenger side rear (RHD car), it is near the rear tyre and fuel tank. Just slide in near the rear passenger wheel and look up. It is not fitted in all countries. Australia and South Africa diesel models have it as standard, because fuel quality can be dodgy when you are remote.
The second filter is NOT fitted to all diesel models. I think it is now an option in Europe.
In Europe the big Diesel water separator is only optional. Thus I want to install one myself, ideally one that can be drained without removing the whole filter. The one from the LR Td5 comes to mind (part # WJN500150) or maybe even the super robust one from the 300 Tdi (part # NRC9708). Does anyone here see a problem with that - like different pressure in the fuel system after install?
Welcome to the forum.
Fuel pressure can be a problem. So if you are going to use one, use the INEOS one.
I spoke with the INEOS staffer in Australia that pushed (with INEOS Africa) for the rear separator, it was BMW they had to satisfy, mainly around fuel flow.
The Water in Diesel Alarm would also work as it does not alter fuel pressure. I used it on my Nissan Patrol for many years, problem is it must be before the OEM fuel filter which maybe a challenge on the IG, as that is under the car. Someone needs to figure out how to install it where the OEM is installed. You would also need to check the diameter of fuel lines to see if it fits.
There is an aftermarket option for the QM in Australia, but I have seen nothing to say it does not affect fuel pressures. So I am not linking it.
I’ve had one fitted by an Ineos dealer in the uk, the only issue is you don’t get the water in fuel sensor which means you need to check it periodically. I haven’t tried twisting the sensor to drain a sample which you can apparently do but I haven’t been brave enough to try. A clear water bowel would be a much better option for me.
Thank you LogSplitter for the welcome!
TheDocAus … yes, i can see that BMW wants that. Just studied the OEM fuel filter (zylindrical horizontal thingy) that is used in Europe. The incoming fuel line makes a very sharp 90° bend, unnecessary in that position from a hydrodynamics point of view. So, since even BMW only cooks with water (as Germans would say), its own aftermarket filter will have some resistance as well. The owner of Blacksheep in one of his latest videos mentioned that he uses a SEPAR-filter (LKF) on his Grenadier and apparently he made it into N-Africa from Europe without issues. So, i am now looking in just buying one of those (not cheap) and testing it. The big advantage is that it has a glass housing so you can see into it and to good old drain valve on the bottom. One does look under the Grenadier anyways from time to time, to watch out for twigs or just to again admire all the stuff down there. So looking into this 'looking glass' before filling up diesel again, one would have the ability to directly see if the last fuel station was a dodgy one or not. I will post some pictures once i did this. Have to take measurements first and see which size would fit best where. I think it needs to go before the BMW filter, so towards the rear end of it.
