New Year Service Overdue Bug
Since the alert I'm not sure if my MPG average figure is keeping up to date. Seems to be permanently stuck at 25.4 MPG
Like right after you fill up the tank? We had that implausibly named “fuel plausibility code” error a year ago or whatever and I got an update - hasn’t happened since. Or is this different?
I’ve got no error codes. But since the service overdue fault, if I get to a stage where I have a yellow warning to refuel then it takes ages to recognise a full tank when I refill. And continues to say refuel soon and for instance 75 miles of range left, even when full. I can clear by pressing and holding the must button for 30 seconds until screen goes blank then resets with no warnings.
I went to the dealer last week to get a few things checked out. They received instructions to temporarily correct the overdue alert instead of waiting for the software update that fixes this bug. While at this recent visit, they also proactively installed a Power Steering Reservoir Cap Seal from Agile Offroad.
Can you explain why the seal on the power steering cap was replaced? I'm assuming the OEM seal is bad, causing leaks?
When I first purchased the Grenadier, I brought this to the dealership’s attention. At the time, they explained that the cap functions as a pressure valve and that some leakage could be expected.
Thanks for posting this, very helpful.
Yes, because it leaks. They have found that the AO seal does a much better job at sealing it than the OEM.
I thought the eCall system was operated by an outsourced call centre 📞 that also serves other manufacturers. I would find that unlikely since the Grenadier doesn't have OTA capability, ( but technically possible??? I doubt and what cost). I also thought the Tesla and the other " et als" had OTA capability and don't use the eCall system for data transfer
I’m highly dubious about this. I have some experience with large automakers and their OTA update architectures.
The e-call cellular modem is almost certainly not set up to distribute code to the variety of modules in a Grenadier that would need to be updated. This code is securely signed, need to be validated as it is being applied, and the idea of using a cellular radio that was not specifically designed for this purpose seems like something that someone made up.
The risk of bricking vehicles through update antics like this is extreme, and the costliest type of blunder an automaker can make. I’m open to being wrong, but I call BS on “finding” and OTA update path when one was not designed into the vehicle. Maybe it was designed for this and we just aren’t aware?
Did they replace the cap or seals? I do not see an AO cap on their site unless I am missing it?
Its just a new o-ring. Super easy to replace. We did all 4 of ours in out group. No technical experience required. Just grab a small screw driver or dental pick, unscrew the cap, pry off the o-ring, install new o-ring, screw back on... thats it.
My SoCal service center reset mine last week so no more overdue for me.
I have the Agile Offroad power steering cap gasket, but mine still weeped over time. I gave an extra ugga dugga to tighten the cap some more. We'll see if it still weeps.
Received this email today:
Terms and Conditions:
Must be a current owner of an INEOS Grenadier. Existing customers can purchase accessories as part of a new MY26 stock or factory order. Accessories can be purchased individually (Rock sliders £199/Side Steps £250/Rubber Floor Mats £49/Picnic Table £175/Seat Covers Front and Rear £150/Full Length Roof Rack Platform £599). Offer prices communicated do not include fitting cost at an INEOS Grenadier retailer. Accessory bundle offer is only available between 13th February and 31st May to existing INEOS Grenadier owners and cannot be applied retrospectively to any accessories purchased previously.
Ironically, my car has been at the dealers since last Wednesday having some fixes on it and I picked it up today and it had the software update and the service warning was gone. Unfortunately, all the settings were reset, and my phone wouldn't connect. I had to delete the existing bluetooth entry on the Grenadier and iphone and re-pair them.
Do you know if it is simply a service indicator reset or is it a software update to fix the service Indicator error permanently? The email indicates software update but less than 30 minutes seems a bit short for that to occur based on past experience of Ineos updates.
In the U.S., dealerships have been resetting it if you happen to visit the dealership. I have my doubts if it’s actually a software update. Maybe it’s different in the UK.
The dealer said it needed to be plugged for it to be fixed, but gave no other details. It could just be a small code change. Mine was booked for several fixes, and it also included two bulletin actions. A software update: IAMWO004241-SP1 UPDATE NAFTA & EU and IAMWO004200 STARTER MOTOR CABLE GASOLINE. The reset in my settings could well have come from that software update.
I am still awaiting feedback for my dealer in Sydney on whether a fix is available now in Oz.
