Hey Guys! AJ From GP Factor. Excited to be a part of this forum as a vendor and lifetime member!
If you are unfamiliar with GP Factor, we produce high end vehicle parts and camping gear in the USA. We have prided ourselves on making parts that do not compromise on quality, and provide years of hard use. We had announced earlier this year that we will be making a full line of parts for the Ineos Grenadier. Currently, we produce one of the best folding tables on the market. We are excited to announced and give you all a sneak peek to the version we will be releasing for the Grenadier! This table is currently based on the same proven design we have made for years for Jeeps, Campers, Broncos, and Land Cruisers. It will be sized and specifically designed for the Grenadier. The specs of this table for your Grenadier as follows:
  • NO drilling or modification. This will use the existing factory bolt riv-nut locations so installation is super easy. You could even use your factory mounting hardware.
  • It will come with our patented cableless hinge design that is both durable and easy to use.
  • Table is made from food Grade 304 stainless
  • One handed dual latch design for easy closing and opening
  • All tables include a ½” bamboo cutting board that can be removed for cleaning or flipped over for dual sided use.
  • We will be releasing a second version of this table that will have a compartment built into the backer (like the factory plastic piece)
FULL LISTING FOR THIS TABLE CLICK HERE: GP GRENADIER FOLDING TABLE
We will be opening up preorders for these in a few weeks and plan to ship the first batch in January/Early February 2024. I have also included in this post some pictures of our existing tables for reference.
You can also find a lot more pics, videos, and other media on our existing tables on our Instagram or website - @gp_factor
We will be releasing other products soon (maybe some stuff you all have been requesting…) for the Grenadier so keep an eye on our vendor area of the forum and also subscribe to our email list as well on our website – Gpfactor.com
Thanks and let me know if you have any questions! Cheers,
Hi GP Factor,
I assume that this then allows the factory fitted aux power to draw from the starter battery and the BCDC back charges the starter from the Lithium house battery (similar to how the factory dual battery system works), or am I way off base here?
Thanks,
Harry.
It has a starter recovery function only.
Not quite. The REDARC BCDC ( Alpha50 for instance ) will also back charge the starter battery if one enables the Start Battery Charge Mode:
Note this mode has a few additional constraints ( noted above ) and it isn’t enabled by default.
Intersting. So that sounds similar to the stock dual battery setup's charging parameters, except for the solar input. Am I tracking that right?
From what I can tell you have to go into the Redarc app and tell the lithium battery to back charge the starting battery. I don't think there's anything automated about charging the starter battery like the stock dual battery system does.
In the configurator App for the BCDC, you choose to enable start battery charge mode. It doesnt have to be turned on each use. In the redvision app (different App) - that is where you chose to run recovery mode if needed. Pic of the configurator app for the BCDC
Does Redarc allow prioritization of solar vs alternator too? I though I read that but can’t find it now. With Victron my solar charge is off when engine is running. I’m not a fanboy the smart alternator either…
Good Morning Grenadier Fam! Quick announcement and update. The V2 of our Grenadier tables is not available and in stock!
Standard:
Cubby:
What so special about the V2? The V2 tables retain all the features customers loved from the original V1 design, now enhanced with a newly engineered bumper system and an extended cutting board. This integrated bumper system securely locks the table and cutting board in place, eliminating movement and rattle when driving down rough roads. The redesigned cutting board shape not only enables the bumper system to function effectively, but also provides a more ergonomic edge, making it easier to pull, push, and handle during use. I dont like holes in table surfaces, so the V2 maintains a completely hole free table surface, as the bumpers are integrated into the hinges. Tables are 100% in stock and orders placed will ship on Monday. Don't forget to use the Forum discount code as well. Any questions, let me know! Cheers!
Upgraded table looks great!!
Quick question - the rubber bumpers putting outward pressure on the cutting board to keep it from rattling is there any longterm concerns about it warping the board especially after being exposed to temperature and humidity changes in the vehicle?
Looking at the detailed images you guys shared it already looks like the cutting board is taking on a slight curve where the bumpers are putting the extended tabs under tension. Curious if the warping will make the board a bit sticky to slide in and out over time?
Ordered one but would like to know as well
