Yes, this is so, slightly!Is this true? Do the under 50 folks need to band together?
Will we have to kick ourselves out and join the geezers when we hit 50?
See the poll we did some half year ago:
Thanks Tom. That’s just what I needed to know. How about getting underneath to the drain plug. Do I need jack stands to raise the chassis to remove the oil drain plug? I used to change the oil on my ‘92 Isuzu Trooper and could barely just squeeze under.I changed mine yesterday at 777miles. It is a very simple process on an easily accessible vehicle. I was initially shocked when I found first the filter housing, but the filter was easy removed/replaced. I am 6'4" tall, and I still stood on a milk crate with a mechanic's mat on the wing to lean on - it's a stretch!.
I plan on 5k mile change intervals, with possibly one more at 2k![]()
Also, I am on board for your oil change interval. Manufacturer’s recommendations are targeted to get past warranty limits, not necessarily to optimize engine life before overhaul.I changed mine yesterday at 777miles. It is a very simple process on an easily accessible vehicle. I was initially shocked when I found first the filter housing, but the filter was easy removed/replaced. I am 6'4" tall, and I still stood on a milk crate with a mechanic's mat on the wing to lean on - it's a stretch!.
unless you are obese you will fit under the vehicle without the need for axle stands/jack etc.Thanks Tom. That’s just what I needed to know. How about getting underneath to the drain plug. Do I need jack stands to raise the chassis to remove the oil drain plug? I used to change the oil on my ‘92 Isuzu Trooper and could barely just squeeze under.
OMG ………! I just thought I was a bit tubbyunless you are obese you will fit under the vehicle without the need for axle stands/jack etc.
Yes, I could reach the drain plug from the from of the car. Laying an a creeper cuts your access/clearance, but just laying on the ground/cardboard it's pretty accessible. The multi-link suspension has more parts than I'm used to. It made for interesting arm positions as I ran my breather lines yesterday!unless you are obese you will fit under the vehicle without the need for axle stands/jack etc.
You have just confirmed what the wife said to me " you are obese".unless you are obese you will fit under the vehicle without the need for axle stands/jack etc.
Incoming !Perhaps this is why our American cousins run 37" tyres?
....taxi!
I just replied to you on the other oil change thread but will go and drop some more in. Crazy how poor the maintenance and info section of the owners manual is.Mine required a litre more than specified on both oil changes.
7.6 quarts did the trick, no warning lights and double OKs. This is a great Forum-thanks Adam!Mine required a litre more than specified on both oil changes.
So, I'm guessing the filter canister volume is not included in the oil spec?7.6 quarts did the trick, no warning lights and double OKs. This is a great Forum-thanks Adam!
Thanks Krabby. Yep, the owners manual says 6.8qts for the B58 (my converter says 6.87 qt = 6.5L). I ended up putting in about 7.2L and got the double OKs.Just throwing this out there - 7 quarts is about 6.62 liters
I too had a touch over 7 qts/liters. My mechanic was conservative with adding additional oil as evidently in the past B58 engines had a bad habit of indicating "low" and would end up with a extra qrt or more in the engine. He's an ex BMW mechanic.Thanks Krabby. Yep, the owners manual says 6.8qts for the B58 (my converter says 6.87 qt = 6.5L). I ended up putting in about 7.2L and got the double OKs.
I know it's not just BMW, but relying on a computer to check something that is really easy the old fashioned way seems foolish. Sure, the computer aspect makes it more foolproof for the average person, but not including a dipstick is short sighted IMO.
