GM Recalls 800,000 6.2L engines
If you think we have issues then take a look at GM. Last week they recalled over 800,000 Tahoes, Suburbans, and Silverados powered by the 6.2L LT petrol engine. The issue is failing rod bearings. Internal documents showed over 30,000 failed engines prior to the recall. The fix it to replace engines that are starting to fail and then change all of them from 0w-20 to 0w-40 to increase film thickness at the bearing.
Personally I have been very skeptical of this ever thinner oil specs. Our 2020 Range Rover Sport has an inline turbo 6 cylinder and uses a 0w-20 with basically the same spec as what BMW is now calling for in our B58. Land Rover service interval is an astonishing 20,000 miles. I have been going 15,000 and now regret that. I did an oil analysis on the last oil change and it was crap. Tons of metals in the oil. I’m not going to move it to a 0w-40 and resample it after 3,000 miles.
These thin oils and stupid long intervals are being driven by fuel economy requirements and marketing. Do yourself a favor and watch this video. Lake Speed is an extremely qualified lubrication engineer. These is lots of talk about how BMW has engineered the current B58 for the LL-17fe+ oil with changes like coated rod bearings but it really makes me wonder. I will definitely be changing oil every 5,000 miles and doing oil analysis to see where things are. The first oil results showed metals typical of break in. I’m doing a second oil change on Monday and will share the results. Hopefully it is a bit more cleaned up.
View: https://youtu.be/pbEdr6Q6cKw?si=AHHwWfLLvNNr1zOc
I changed my Grenadier's oil at 700, and just now at 1,600 miles, using Liqui Moly's Top Ten 6600 0w-20 LL-17FE+, while I wait to get results back from SPEEDiagnostix. Once settled, I'll change between 3k-5k. I do want to see if 0w-30 or 5w-30 would be better in the summers (today, upper 90s in DC-MD-VA area), and back to 0w-20 in the winters, and send in the samples, see what wear is happening, but would love for INEOS to respond with: we require 0w-20 LL-17FE+, but using 5w-30 LL-04 won't void your warranty.
I saw that. Very interesting. Sure glad that I don’t own anything with a 6.2 in it. That flaw isn’t going to last long with just a change in oil viscosity. The ones that don’t fail under warranty are going to fail down line and some owner is going to get stuck with a big bill.
Likely the reason oil viscosity was increased for a fix. The surface finishes years ago are not as good as they are now for the low viscosity oils but old tech engines lasted a long time on higher viscosity oils.
What is said here makes sense, but I had a VW V10 Touareg with 170,000 miles, that ran 5W - 10W its entire life. And it is still going strong. Changing the oil every 5k miles is probably more impactful.
