Hah, yep they aren't fun. Once you have done a few they seem to get infinitely easier though.This is the worst mechanical task I have ever undertaken. No thank you, please!
No fun at all and why I always engage the services of my local drive line shop. The turn around is usually withing 48 hours and totally worth the cost.This is the worst mechanical task I have ever undertaken. No thank you, please!
This solution was on the front of my 2001 Grand Cherokee from the factory. It lasted about 150k miles- and only then started to vibrate a bit on deceleration at highway speed. AWD for the record, so it was getting the same duty at the Grenadier does.Well, my opinion is, we’re relying on the centering ball on two sides to support the driveshaft and keep it from being floppy. That seems to be beyond the design and precision of the manufacture and the units that have been made have had some harmonic interaction. No one that has made one, has decided it was worth while to make 100 and test them to collect sufficient data for anything more than an opinion.
So what you’re going to get here are opinions, but I’m sure there’s someone somewhere that can give a proper theory/explanation outside of this forum if you search hard enough. I didn’t think it would work, I’m ok moving on knowing there have been a couple attempts and failures. I guess there’s a reason I’ve never seen an automobile manufacturer utilize this solution .
One of these days I will stop beating this dead horse.This solution was on the front of my 2001 Grand Cherokee from the factory. It lasted about 150k miles- and only then started to vibrate a bit on deceleration at highway speed. AWD for the record, so it was getting the same duty at the Grenadier does.
This solution was also found on my 1965 Cadillac Eldorado with a 6 foot, 35 pound drive shaft- unmolested since it was put together at the factory. History of that vehicle was difficult to determine, however it was clear that it hadn't been rebuilt and it was smooth as silk for the entire duration of my ownership.
The Grand Cherokee was a telescopic drive shaft. The Cadillac was a slip-yoke into the back of a Turbo-400. Neither of them had the angles of what a Grenadier has, and that may well be the difference.
Those aren't pillows!It will then vibrate like a cheap massage bed in a 70-80's era motel and tear itself apart.
The jeep shaft you are talking about uses the long boot at differential side of the shaft only. The grease from the joint does not migrate into the boot and harden because the boot is uphill of the joint. If you used that style boot on the jeep or Grenadier at the t-case side of the front drive shaft then you will send all the CV grease into the big floppy boot and it will firm up and stick in the boot on one side. It will then vibrate like a cheap massage bed in a 70-80's era motel and tear itself apart.
Can we be done with this suggestion? I know it's new people coming into the convo, but damn son!!!
Never put vibrating beds and your mom in the same sentence.Well thanks for beating it, because this thick head needed a few extra minutes to put it together. You and I are talking about different drive shafts.
I don't remember seeing any of those beds in my adult life (I would have tried it) and my mom would never let me drop a quarter in one when we were young.
BadHi guys, I learned a lot reading this thread. I am considering the agile driveshaft.
Does anyone have experience with one. How bad is the vibration. Are we talking death wobble here or what?
Perfect summation of the options.Options are:
I’m sure I’ve missed other options feel free to add.
- Leave the suspension stock and get on with life and replace front transfer CV joint when it finally does let go
- Put on a big boy lift kit and at the same time big boy pants and replace CV regularly - then hit the trails and enjoy life
- Get used to vibrations of an aftermarket driveshaft solution and possible long term issues it may create
- Engineer a driveshaft yourself or try and convince local driveline shop to cobble together a double cardan and rezeppa setup and deal with its quirks and their initial reluctance to build it even if they can
- Fiddle with front axle caster to slightly reduce driveshaft angle and deal with a bit more steering weirdness
- Hope IA will eventually issue a recall (no chance in hell)
- Hope IA will eventually redesign the front geometry (slightly less chance in hell)
- Enjoy the vehicle you have and save some pennies just in case they ever do fix it on a future model and trade up.
“Maybe that gets me 20K miles between CV changes.”
Correction to the above. I would work with my local drive line shop to build a Double Cardan-Rzeppa combo shaft. A CV-Rzeppa is what it comes with stockPerfect summation of the options.
My choice is running no lift with the largest tires possible and dialing back caster to 1.5 degrees. Maybe that gets me 20K miles between CV changes.
If in the future I decide a lift is necessary I will work with my local driveline shop to build a CV-Rzeppa combo shaft. Maybe it works, maybe it does not.
At 1.7 I have a vibe at 61 mphDoes anyone else with a 1.5 lift get a vibration with the stock shaft? That seems odd. (The truck does have drone at 2000rpmish at highway speeds, but that’s not the shaft.)
Problem is most shops can't balance a shaft with Rzeppa joints. This includes shops like Tom Woods.Correction to the above. I would work with my local drive line shop to build a Double Cardan-Rzeppa combo shaft. A CV-Rzeppa is what it comes with stock.
My local driveline shop told me they can do it. Maybe they just want the business and will wing it, but I have worked with them for over 20 years and they have always done exceptional work.Problem is most shops can't balance a shaft with Rzeppa joints. This includes shops like Tom Woods.
Even with no lift in MY23, around the same speed I get it.At 1.7 I have a vibe at 61 mph
