Front Drive Shaft Update
Behind where my light shines on the curve of the flexed boot the bearing behind has effectively moved out of the way so there is plenty of space . There is no pinch that I can see. Plenty of free space at the point of the shafts maximum angle which is only restricted by the metal flange. Not the boot in any way.
I can see debris causing this and I can see rubber fatigue at the change in thickness of the boot. That's it.
The metal flange reduces its aperture back about where the boot curls back on itself. This is the first point of contact. If you dissect the boot you will see telegraphing of the machine marks from the shaft and the texture of the metal flange.
It happens on both stock Grenadier and The Terra Joint.
Ahh ok.
I'll dissect my wasted joint soon and post pictures. Thanks for being patient.
Install of the new joint was pretty simple thanks to everyone's tips and tricks that made it a smooth process. Nothing difficult about it really as long as the bolts come out you have the right tools and time. Good to do once to feel more confident with long distance remote travel. Id take a spare shaft as they weight only 13kg I estimate.
Ahh ok.
So I don't upload the pics a fourth time.
Post in thread 'Front Drive Shaft Update'
https://www.theineosforum.com/threads/front-drive-shaft-update.12418127/post-1333378486
So, while people are complaining about the front drive shaft on the IG, it seems that there is a whole swath of gear for new drive shafts on Jeeps? Maybe not an issue on stock Jeeps like we have the drive shaft issue on stock IGs, but still a thing. And the replacement Terra Joint has issues too?
A little schadenfrued, but at the same time maybe a sign that there isn't a perfect 'solution' to the drive shaft issue? So, if you lift a Jeep, maybe higher than an IG, people often replace the drive shaft.
Considering what I spend on rock sliders, skid plates and an air compressor, a new drive shaft doesn't seem crazy- especially with a lift. Heck new steering is expensive.
I'm still a bit confused as to what is the prime driver of the failure of the front drive shaft.
It's the boot that fails, correct?
Is it a wear issue or a sudden issue- and is that driven by small variations in boots (manufacture or installation)
Stock jeeps didn't have the joint issues we have. Certainly there were failures on stock jeeps, but that came with very high mileage and abuse. Once you lift a jeep you start hitting the max angle and the boot gets damaged.
The prime driver of failure on the Grenadier is that max suspension travel allows the driveshaft to exceed the safe operation of the CV joint. If only fractionally. This causes the boot to be squeezed or pinched lightly. This action plus the heat from the joint etc causes the boot to thin out. Eventually the boot gets to thin and the rotational forces are too much and the boot finally splits where it was thinned out. This split turns into a tear that can go just about any direction at that point. The split can be purely brought on from general thinning or it can also be aggravated by cycling the suspension a bit more than usual and forcing a split/tear earlier in life.
Seems like if there were a mesh in the plastic matrix, or some short fibers in the plastic, it would make it less prone to tear? What is the boot made out of, vulcanized rubber? Lots of advances in TPU/TPEs over the past decade.
I guess just making it more ‘stout’ with thicker walls might make the MORE prone to fail due to more likelyhood of pinching?
Seems like there are so many engineering paths to follow to fix this.
Anecdotal but talking to someone who drove from Middle East to Iceland and is correctly planning a cross-Africa trip. She thinks her under body protection stops small rock chips hitting the boot and prevents tears. Her’s is lifted but think a 2” if I remember correctly.
Not a bad theory.
What kind of under body protection is installed there?
Hydraulic compensators are made from layering fiber reinforced rubber.
Not a bad theory.
Wish it is that simple…
Im seeing some of these messages on Sven's driveshaft. Im wondering what some of the experts think of this prospect. Will it solve this issue? Is it just a wait and see thing and we won't know until people have enough KMs on them?
I heard or read somewhere that was most likely boot failure and once that happens and contamination gets in and grease thrown out is matter of time before joint fails. I also was told that the factory has a solution they are going to be putting out on new Models...not sure if a MY2026 fix or will be available aftermarket or is requiring some other mod to make it work. Been reading this thread and not yet up to page 94 yet but I hate reading backwards. LOL
You will have to give us a bit more information here....... Even direct discussions with leadership has got us nothing that would align with what you are hearing.
went out last evening and checked all of my boots front and rear on Grenadier. Ran finger around on inside and all are clean...and didnt feel any picks, nicks, cuts, rough spots. I have 20,000 miles on my 2024....not done any trails requiring climbing ledges or anything yet like my Land Cruisers......but so far so good. I have done a few 3+ hour trips at highways speeds as well.
I will just make checking them part of my weekly/monthly checks on my vehicle....maybe daily if I go out to Iowa or N Dakota bird hunting again this year from east coast. WHen I swap out the wagon for a Quartermaster in couple months...will do the same on it as well. My plan from beginning is to put 34/35 inch tires on with no lift.....and have found I can wheel anywhere I want with that setup from experience with FJ60, FJ62, FJC, UZJ100 over the past 25 years......east coast trails in Uwharrie (Daniel, Dicky Bell, etc) and everything around Ouray CO (Black Bear, Engineer, Poughkeepsie, Immogene, etc)....diff protection...some skid plates, rock sliders....and has always been enough. Anything I have been confronted that might actully require 40" tires or larger were really not Offroad Trails....but Buggy Trails instead for serious Rock Crawling where putting a wheel up on a bolder or a vertical wall climb over 4 feet.....99.99% of offroaders will never encounter those things...and are typically an ALTERNATE TRAIL for those so inclined. LOL
I’m not entirely sure why highway driving, even at higher speeds, should be a primary cause of boot issues. While there’s more heat and faster shaft spinning, the shaft operates at its lowest impact level due to minimal articulation from consistent flat road conditions.
I think it might relate to the fact that the speeds and the heat may be higher. That might be an indication that some boots aren’t installed perfectly, that there’s kind of a inherent design, flaw, or just an overall weakness in the boot design? without real world data as to the probability based on configurations, I guess it’s hard to know.
