Agile Off Road Front Shaft
Based on what?
There are double cardan joints on the front axle of IG. Commonly used on HD axles.
On Discovery 2 the front prop shaft has one DC joint (on transfer case end) and original quality shafts have a lifetime of > 150' km (100' miles). And no vibration.
Yeah, I've been curious why the Agile shaft didn't look like the Disco 2 DC one. It worked fine for me for many years with the standard OME lift, which I think is about 1.5".
I have I guess the 2" lift on Terra joint. Zero vibes and not much if any droning.
I did get buzzing vibes when my original joint was going out.
Buzzing vibes. Can we talk about this real quick? Since my last service about 1000 miles ago, I have various areas of buzzing that seem more like the dash and rear cargo area plastics rubbing together. I am at 16,500 miles. I have tried to push and move the plastic bits to eliminate it but to no avail. I do have a lift, so I can view the unercarriage easily. Should I be focused on the boots at the propshaft(s) where it connects to the transfer case, is it the yoke, looking for tears or something else? Can anything be seen in advance that anyone is aware of?
P.S. I am bone stock suspension wise. no off road travel only asphalt (Tarmac)
