Front drive shaft broken
When I made my loop mount bracket I left a 4-hole tab so I have somewhere to mount a camera, or a laser thermometer, if I want to observe the CV during operation.
Maybe some electronics whiz in the aftermarket can come with a solution to monitor CV joints.
M
Donno. Seems crazy that you would need a digital screen up constantly to monitor tcase temp for excessive heat when driving. So much for using CarPlay.
You should try the Off-Road screens. I've pretty much cut the CarPlay cord and mostly use other screens unless I need active mapping.
M
Yes I do use them to check tire pressures, gearbox / case temps when towing and they are good. But I have CarPlay up 99% of the time for on-road/offroad maps and music :)
Why would the tcase temperature provide insight into the front shaft’s cv condition ?
The theory is that the CV is mechanically connected to the T-case and that acts to a degree as a heat sink for the CV. But the reality is you won't see any appreciable change in temp and what you do see will be too late.
I’ll take two! (Can I get a “suitable for framing” photo of this ‘fix’ to put on my dashboard, so that I will feel better for now?😅)
IR sensor: $2.41. Circuit to turn the yellow/red LEDs on: another $10 in parts.
The diff end is super easy to mount on most aftermarket skidplates covering the pinion. The T-case end can be mounted on the transfer case crossmember.
Pending a permanent fix, would periodic (or constant) monitoring of the Transfer Case temperature (on the Offroad display) provide any early warning of a failure such as this?
lol just don’t lift then. Get a jeep you if want to crawl rocks that badly or want that tall stance…
Latest posts
