Agile Off Road Front Shaft
I wonder what % of owners can actually physically crawl under to check their CV joints. Without their own joints tearing or dislocating.
Or knocking their prescription goggles off.
I suppose one advantage of a lift is it's slight easier if you are "large boned" 🫠
Nonetheless I doubt whether many chaps are slipping under the machine on a weekly basis.
So perhaps someone can market Propshaft Cam with infrared sensor?
It's a thought; I'll admit not a great one.
I may think about a lift. I have the space for it and I’m not getting any younger. Just last weekend a small magnetic shop light slipped down under the engine on my Wife’s Defender Trophy. Removing front-/mid-skid plates and underbody cladding was a chore, even with the wheels on 8-inches of cribbing.
Inspecting these ‘boots’ has become part of my daily routine on the trail. Were the “micro cracks” visible and/or detectable by touch? Can you provide any photos so that we can all know what to look for?
TIA,
Bill
I’ll have to draw back under there and get a few. I’ll post back soon.
TIA,
Bill
It's pretty minor. Looks a little dried out. This pic is from my front CV on the front shaft. But all are showing it in some fashion.
Curious if the occasional application of 303 Protectant could help keep the boots somewhat supple without being overly sticky and attracting dust?
Originally engineered for aerospace and aviation applications, new 303 Automotive Protectant provides superior UV protection for any rubber, vinyl and plastic surfaces of your vehicle, such as your dashboard, windshield wiper blades and even your tires. Unlike many protectants that leave greasy residues, 303 Automotive Protectant dries to a clear matte finish without that sticky, shiny slick feeling. 303 Automotive Protectant not only protects against fading, discoloration and cracking from harmful UV rays, but repels dust and stains, too. Simply spray on and wipe dry for a beautiful, matte finish. Best of all, each application will last up to 30-45 days. Great for use on a variety of surfaces such as: vinyl, plastics, synthetic and natural rubber, leather, eisenglass, PVC, gel coat and fiberglass. Ideal for use on your dashboard, other vinyl/leather interior surfaces of your car, tires, windshield wiper blades and more! Not for use on unfinished leathers (such as suede), fabrics (canvas) or floorings.
  • Keeps surfaces looking newer and lasting longer
  • Provides superior UV protection from cracking and fading
  • Leaves a dry, matte finish no oily or greasy feel
  • Helps repel dust, lint and staining
  • Brightens surfaces
Weather checking is not the issue. Plus the stock part has a light coating of some kind on the boot that may look like it has cracks but it's just the film on the rubber.
The failure comes from constantly extruding the boot by pinching it. This happens over time and is not visible from the outside. You will only know you have a problem when the boot has actually torn. It's a dramatic thing not something subtle you have to get up close to see. Now it may be that the tear is on the top of the joint and hidden from view but if you are paying attention you will see it.
Again, the tears or cracks are dramatic. You won't need your readers to see the damage. And the damage leading up to failure is not visible from the outside of the joint.
And finally, if your joint is glowing orange then the boot probably failed some time ago and you just missed it.
Nice thought; once it gets a little crack - like leather , you can't magically heal it.
I just noticed early failure of mine.
EDIT: On closer inspection at night with a bright torch mine is OK. 360 rotation.
Nice thought, but the boot is a fairly hard plastic substance and not what you'd call supple. Once it gets a little crack like leather you can't magically heal it.
Yep, you have some damage for sure.
That said, the rubber is pretty supple once you get it off and feel it. But you are right, a rubber spray is not going to help.
I’m still trying to decide if “extrude” is being used properly here. I’m not picturing it in the typical definition of material being forced thru something. Please describe what is you see happening to the boot when you say it is being extruding.
The boot is basically being rolled through two rollers and extruding the boot making it thinner.
Roller #1 is the drive shaft itself.
Roller #2 is the boots metal collar.
Not enough force to bruise but just enough to work the boot over time thinning it out. Eventually it gets thin enough that the boot tears apart from the rotational speed.
You will see a distinctive crease or ridge at the folding point where the extrusion pressure is the highest. See the radial ridge in the pic below. Thats not there when the boot is new. You can even see the machine marks from the shaft imprinted in the rubber boot.
You will see a distinctive crease or ridge at the folding point where the extrusion pressure is the highest. See the radial ridge in the pic below. Thats not there when the boot is new. You can even see the machine marks from the shaft imprinted in the rubber boot. View attachment 7917515
Is this conditional or physical contact? Is the rubber boot thicker than the gap between Rollers #1 & #2? If Yes, then that collar must be modified.
Contact is conditional. As the suspension extends to its fullest extent. The folded rubber boot is thicker than the gap between rollers.
I have a plan B or maybe it was plan C that involves slight modification of the boot and collar. But I need to make some dies to do that and I'm not certain it will work due to the necessity of bolting down the boot and joint. The joint is already designed to allow access to the bolts and provide the maximum amount of angle. Unfortunately we exceed that angle with stock suspension.
Hi guys, please forgive me for my likely obtuse question-is this failure happening on stock rigs too (no lift)? Thanks.
Been done, and it vibrates. Double DC shafts are not great for full time 4wd. The centering ball is a bit of an achilles heal for the DC joint.
Based on what?
There are double cardan joints on the front axle of IG. Commonly used on HD axles.
On Discovery 2 the front prop shaft has one DC joint (on transfer case end) and original quality shafts have a lifetime of > 150' km (100' miles). And no vibration.
Based on what?
I never got that many miles on my coil sprung LR's with DC shaft. The centering ball rebuild was required more frequently than I would have liked. I'm now very hesitant on the DC joints, but if it's proven to work on the Gren I'd buy one tomorrow.
Based on what?
A sole DC joint does fine. They start to grumble eventually and do need a center ball rebuild but that takes time. It is a very well known issue though.
However where you really get into trouble is when you have a DC supporting weight at both ends. This is where the DC starts to flounder hard. DC joints just don't do well when both ends of a shaft are allowed to flop around. Even small amounts of wear to the centering ball causes significant vibration. This wear is then exponential and things get bad very quickly. Ad in that everyone like to over size these joint by using say 1350's when 1310's are plenty strong and you end up with way more mass trying to tear itself apart.
