Who is experiencing software or electrical gremlins?
jkloy
10:48 AM
Groß-Umstadt
I got that message 2 days ago when playing around (some of us can't help experimenting with the controls)
I held the restart button before turning the ignition on and bingo! Error message.
Had to turn off , lock car and wait a few minutes. Then it fixed itself.
Thanks Tazzieman, that is interesting. For me the message popped up during driving on the highway. And I was definitely not driving in offroad or wading mode. After a short break when car was switched off and on again, the message disappeared, just to pop up again have an hour later during driving. Strange thing.
Logsplitter
9:48 AM
I’m on the old software version on my Petrol engine and every time I fill up I get a standard >450 km range indication which seems to be about right for the conditions I’m driving in
coloradosnow
2:48 AM
Denver, CO, USA
Tonight, driving in the country, with my recently picked up Grenadier (only 220 miles on the odometer), at 50mph on a country road, the tell-tale screen lit up like a Christmas tree.
  • All yellow
  • 7 of them. Maybe 9. Here are the ones I could remember
  • B1 (esc fault)
  • C2 (forward collision warning)
  • C5 (front camera warning)
  • C11 (overall warning)
  • B8 (check engine)
  • B9 (transmission failure)
Note, after turning off the engine, the yellow B9 (transmission failure) stayed on. Nothing changed in how the car drove from when the lights came on. I also turned off the engine, removed the key, to see if they would go away. Nope. They all came back on.
Anyone experience this? Suggestions? Thanks!
MrMike
4:48 PM
  • All yellow
  • B1 (esc fault)
  • B8 (check engine)
I suggest you take it to the dealer and get them to diagnose the issue, all other comments will be purely conjecture (y)
jkloy
10:48 AM
Groß-Umstadt
wow...that's a lot. That many warning light I have only during the ignition sequence. Before my software update, I had a few that occasionally light up while driving. Then after the software update no warning lights until recently suddenly the ESC-OFF light in yellow came up in the middle of driving.
6:48 PM
Has anyone found their Key to be a bit iffy when locking/unlocking the car?
No , but dirt/moisture could get in; also the battery might be dying or slightly off course .
I'd replace the battery and see if it fixes things.
coloradosnow
2:48 AM
Denver, CO, USA
I suggest you take it to the dealer and et them to diagnose the issue, all other comments will be purely conjecture (y)
good piont, and agree. Sadly I am 200 miles from my dealer, in the mountains, in winter, at Christmas time. Not the ideal circumstance! Appreciate the reply.
KDJDGrenadier
6:48 PM
Brisbane Australia
when i unlock the car and start driving i have rear door open alarm goes off when accelerating or over big bumps. I recluse the doors and the problem goes away.
Murray2105 I drove my Grenadier on a recent trip on some outback highways and when going through dips i would get a 'bong' sound. Had me confused but I have read recently that it is to do with the adjustment of the rear door. The car must have sensed a momentary open signal and hence the bong sound. Dealer readjusted the door today but it happened so infrequently it might be a while before i test it out.
Shopkeep
6:48 PM
I had my software update about two months ago and first it looked all fine, but now since a week or so I experienced a new error message, saying: ESC-OFF - downhill/uphill assistent not available. It seems to appear randomly while driving.
And another issue, which my dealer could not explain is the following: When I fill up the car to 100%, my display shows the remaining distance in km just as >570 km instead of the correct number as you can see in the picture. My question: Has anyone same experience with the display? What is shown there, when you when your gasoline tank is fully filled up? I would appreciate, if you could show me photos, because my dealer argues that this could be a restriction on the display which possibly cannot show more than 570. I think, this is a silly explanation....why should any software engineer restrict the display just to that number?
I get the same >570 for a while and then it starts to count down. Does not bother me, I am only worried when it’s says 20 or less.
6:48 PM
My last fill up it dropped to ">390"..
6:48 PM
Maybe you drive it like you stole it and it’s just being realistic???
Maybe it's just the gremlin. When your vehicle's named Gimli , expect an orc or elf in every system
jamesfielding
9:48 AM
Malvern, UK
A new one for me today. Engine Control Error. Just in the local cash wash and when I’ve started the engine to move forward a couple of feet it’s flashed up on the infotainment screen not the Warning Display
Skydance
9:48 AM
MANCHESTER
I think the Grenadier is long due another software update (after the previous one) as most people have reported different gremlins. My dealer wants to change the reverse sensors. I told them not to. It’s a software issue. It sometimes continually beeps. Beeps when there is no one sat in the rear seat (stops when I put the seatbelt on). High TPMS wheel warning. All of the issues are intermittent.
