Towing Electrics - Caravan fridge
JohnHeagney
9:09 PM
Hi All,
As we know the Grenadier towing electrics are set up as the Continental way that doesn’t have a live feed for a caravan fridge.
My Dealer offered to do this work but today I called in to the guy who does my towball and electrics to see if he could do this as we are going away with the caravan before mine goes back to the dealership next.
Has anyone worked out where to take a live positive feed from to wire into the electrics socket so that the caravan fridge will operate correctly?
I would very much appreciate knowing from anyone who has managed to achieve this!
Thanks in anticipation,
John
Hi All,
John
Do you have the Aux battery?
In Australia we normally run a separate 50 amp Anderson circuit from the car's battery to the caravan, and the caravan fridge is powered by that. So two cables are plugged in being the towing electrics and the Anderson power. I had my Grenadier wired this way, but that does not help you with socket power.
It can be an alternative if the other way does not work.
Thanks, over here in the UK it is normal that the caravan fridge takes its power during travelling from the multi pin socket. Thanks, John
John,
Did you get anywhere with IG sorting this out for you?
I've just raised a ticket with them for the same as the dealer here has quoted £600 + vat to upgrade to the fully operational plug.
Grumpy
John,
Grumpy
My local and very good tow bar man did the electrics, a perfect, immaculate and neat job too for about £150. All good now!
I don't know anything about caravans and caravaning but when I mentioned the omission of ignition power to pin 10, I was informed ( and to be fair I wasn't paying much attention since I only tow trailers) so I hope it makes sense to you.
" the modern thinking on fridges when towing is the permanent live is used and controlled by the " habitation" switch within the caravan, ehat ever that is.
Hope you can make sense of that and perhaps explains the deliberate omission by Ineos
To be fair to Ineos, as I understand it, on the Continent they don’t run with caravan fridges operating, it is a British “thing”! 😀
Regarding the missing pins on the plug.
IG got back to the service centre and said there is no immediate solution but an accessory pack to fix this is in development and will be available soooon!
I shan't hold my breath.
G
Has anyone sorted out this issue yet.
I don't have an issue with doing it myself but it would be good to know how to connect it to the correct supply I was thinking about fitting a relay with a fused supply off the battery and control it from something that's only on when the engine is running.
Probably your simplest option is to use the permanent 12v from the towing socket and use a voltage sensing relay in the caravan to turn the fridge on when the engine is running.
However most VSRs have a fixed on/off which doesn't work very well with a smart alternator.
Have a search for a Victron BP. About £30 these can have the on/off set (by Bluetooth) so that the fridge doesn't switch off when the smart alternator senses the battery is fully charged.
That will work!
I have decided to purchase and fit this split charger from Towsure, I'll update on how I get on.
If you are going to do this lots of photos please.
My towbar guy would not touch it and Buzz would not give me a price just an hourly rate ?
How do you intend dealing with the missing pins in the socket?
Cheers B
Bob ineos,
Got this completed this weekend.
So took power from the 40a feed in the area next to the auxiliary battery. Took power (permanatly live) and the trigger that goes live when ignition is on round to the area at the jack. Linked through a relay and switch, out below rear light cluster and along behind the heat shield above the rear d kid pan.
Bought a new 13pin socket, cut off the old and pieced in a new loom and reconnected all the wires.
Everything works well and a separate swith to operate fridge if required.
