Towing Again
For those asking questions about jockey wheels and doors.
Brian James cargo connect trailer.
Jockey wheel clamped fully up:
And jockey wheel just lowered to the ground:
View attachment 7816516View attachment 7816518View attachment 7816517View attachment 7816519
View attachment 7816520View attachment 7816521
Hmmm I've IWTs but I'll willing to bet the jockey wheels are in the same place. Since I suspect they are both Knott, I'm going to have to take care. The one I'm waiting to try is the tow ball mounted bike rack
Hadn't thought about this! Do you think a jockey wheel sitting at 700mm back from the towball would clear?
Good thing about jockey wheels is that on most trailers they are easier and cheaper to replace and relocate than doors.
Yes, might have to add a spacer to move it back a few inches, the WDH brackets & bars prevent it going on the outside of the A-frame.
Well mine measures 575mm from centre of towball to centre of jockey wheel, so I d think 700mm is going to be well clear of the large door. 👍
@JohnHeagney ~ did you get any response to this question?
And can you confirm whether the backplate comes with all 6 holes pre-made to align with the Vertical Towing Interface bolt pattern?
This was the response from Ineos:
Hi John,
Just getting back to you regarding the drop plate query you have raised earlier.
It should not pose a problem. This sort of adaption should not pose any additional strain on the tow bar system. However, we can't be accountable for anything if the adaptions were to fail.
To ensure the adaption works in the long run, perhaps making additional checks every now and then should help to prevent any issues.
Please do not hesitate to contact us if you need any further assistance.
Thanks,
Denis Barinov
INEOS Grenadier Customer Service
Hi John,
Thanks,
Denis Barinov
That email could have been shortened to something like:
“Dear John. Thank you for your enquiry. You are completely on your own”.
