rear door latch adjustment how?
Do the rest of the front interior lights come on?
The rest of the interior lights do come on in accordance with passenger door switch logic, but then the dual lights over the rear seat do not extinguish when the front seat lights do.
When I open the 30% cargo door, only the two lights over the second row (rear seats) illuminate. After I close this door and lock the car, these same sights remain on for about 15 minutes. As before, the single light over the loadspace has completely stopped working. Ideas?
In that case ,probably a connection failed somewhere. But where ?
can you check with a voltmeter if you have access to see under the light
If there is voltage, then it is a bulb issue
If no voltage ,then it is likely a wiring/connection issue ,I think
Can't recall without checking but I think they are LEDs, my money is on a contact switch
Hi
rear door is a pain...
it does not shut properly with reasonable force and has to be strongly pulled from the inside to shut properly
Otherwise ,chime every time you stop /start !!!
I understand that adjustments can be made to the latch
Would anybody have an idea about what to do ?
NB :same with bonnet ,but to a lesser extent
Kind regards
I made a video on it if that helps
View: https://youtube.com/shorts/lDChT48oaV0?si=3wvrFpUL0xv3QQOb
Thanks for the video, my dealer just told me I wasn’t closing (slamming) the door right and it’s fixed. The first bump after leaving the dealer: Bong
Is the a TSB for this I can reference?
Just loosen the latches using 13mm ratcheting wrench.. move the latch out a few mm. Retighten..
Trial n error
I got luck and fixed it on the first go, by moving the top latch like 3mm
Did you watch that video? Literally shows you how to do it….
