The rest of the interior lights do come on in accordance with passenger door switch logic, but then the dual lights over the rear seat do not extinguish when the front seat lights do.Do the rest of the front interior lights come on?
Can't recall without checking but I think they are LEDs, my money is on a contact switchIn that case ,probably a connection failed somewhere. But where ?
can you check with a voltmeter if you have access to see under the light
If there is voltage, then it is a bulb issue
If no voltage ,then it is likely a wiring/connection issue ,I think
I made a video on it if that helpsHi
rear door is a pain...
it does not shut properly with reasonable force and has to be strongly pulled from the inside to shut properly
Otherwise ,chime every time you stop /start !!!
I understand that adjustments can be made to the latch
Would anybody have an idea about what to do ?
NB :same with bonnet ,but to a lesser extent
Kind regards
