Good point that’s why it’s better to put a step on the hinges.One consideration, the utility rail is only rated to hold ~40kg on the door
Thank you for your response. I’ll have to think about it.Good point that’s why it’s better to put a step on the hinges. View attachment 7904657
I’ll have to ask the dealer to release it.Buzz and DVA both make one, I opted for the Buzz kit like the photo. Very happy with it. Note the factory bolts can be difficult to remove would advise having your dealer break them loose before attempting install.
As you say they were bloody tight so have to make sure you have really good torx bits or they’ll snap.Buzz and DVA both make one, I opted for the Buzz kit like the photo. Very happy with it. Note the factory bolts can be difficult to remove would advise having your dealer break them loose before attempting install.
Thank you so much for your advice.One consideration, the utility rail is only rated to hold ~40kg on the door
The paint on the screw could come off, and it might even break — it really gives me a lot to think about.As you say they were bloody tight so have to make sure you have really good torx bits or they’ll snap.
One of mine was over-torqued from factory and had a lot of paint in the head, I stripped it and it took 3 master machinists at one of my factories half a day to get it out. I'd suggest either:The paint on the screw could come off, and it might even break — it really gives me a lot to think about.
I’m taking away so much valuable information. Thank you.This is the bolt shank after they finally got it out, had to drill the head off first. You do use new screws that come with the steps, your original ones will 100% have at least some marks on the paint when you are done. You can touch this up easily and worst-case scenario a new factory door bolt is under $10 USD.
Happy to help. For reference I am 1.7m and by standing on the Buzz step, rear tire or rear bumper (I have the ladder as well) I can easily reach all but the very front of the roof. I went with three Leitner load bars, not rack, and can get at everything without trouble. I keep heavier or bulkier items e.g. Maxtrax on the rear bar because I can stand on the bumper with the rear doors open and load them without any risk of damaging paint.I’m taking away so much valuable information. Thank you.
