DVA Utility Belt Bolt Torque
Chris U
5:07 AM
USA
Anybody have a torque spec for the bolts holding the utility belts on the side?
This is from online manual factory screws and rails.
My experience with DVA screws and rails were the screw heads were too small for the rails holes and would not take anywhere near that torque without pulling through. (It is actually the hole diameter that is the problem, too large for m6 countersunk screws)
They sent me larger headed screws which worked.
Orignal screw head dia: 11mm
Replacement screw head dia: 12mm
Cautionary tale...
Cautionary tale...
This was my observation as well.
I replaced mine with 316 stainless and torqued them to 8 foot pounds with pink (lowest strength) loctite.
