INEOS AIR FILTER PART NUMBERS (also Air Cabin filter)
Seems like I found the producer of the cabonfilter: https://www.eurogielle.it/en/catalogue/7135/ officially:219*212*25mm
I will try two versions with almost similar measurments:
217*195x25:
- Bosch 1 987 432 273
- Mahle 569
- Mann & Hummel CU 2227
214*214*25:
- Bosch 1 987 432 299
- Mahle 430
- Mann & Hummel CU2132
Has anyone tried one of these yet?
[td]
[/td]​
The 1 987 432 273 looks promissing. Just the foam of the original filter shows a little bit.
The 1 987 432299 is probably a bit too long. (see photos)
I will try next Week and report back.
The Version 1 987 432 299 doesn't go in far enough. So this one won't fit.
The 1 987 432 273 needs a little push to the sides to get in and fits not perfekt, but not bad at all. (see photo) At least it might be an option...
With active charcoal the number would be 1 987 435 595.
How did they perform?
Well, better than the factory filters, but- the factory box leaked dust into the clean side, IMO they aren't needed in the Grenadier. After weeks in the East Pilbara on some seriously dusty tracks there wasn't a spec of dust inside.
Some 200 series owners said the oil from the filters would get on the MAF sensor but I personally didn't have that issue as I cleaned it when I serviced the filter.
Just look after your filter and carry a spare if you're really concerned.
