INEOS AIR FILTER PART NUMBERS (also Air Cabin filter)
You joined the forum 58 minutes ago and you have access to this information. Are you going to reveal yourself or give us a bit more insight. 🤔
Initially, I thought the same, but after doing some research, I realized it's a lifetime product.
It can be cleaned and reused, and it even comes with a lifetime warranty.
It’s more like an investment ; it starts paying off after the third service interval.
Just imagine using a disposable paper Mahle filter at every service. By the third replacement, you've already saved money.
I will share my feedback after some hard off road use.
the problem with them is even if they last a lifetime
they let so much dirt into the intake you will replace the engine before the filter
here in the southwest where you see dirt and not grass they dont work well
where there is a lot of grass and mud they may be alrigh
I will pay for the paper and keep the engine
I was thinking the same, but the feedback so far is actually quite positive. The filter seals very well, and the main filtering media effectively stops all dust and debris.
The oil on the filter also does a great job collecting all the bad particles.
Filter looks like the same as KN but it has a better quality.
Before purchasing, I did some research on the company and saw that their filters were used in the Dakar Rally, where sand is a serious issue for engines; and DNA seemed to hold up really well under those extreme conditions.
I’ll keep you updated on how it works.
Cheers!
I just had my HVAC filter replaced today in a diesel station wagon during its 15K service and the part number is listed as GRA-2G00036590. It appears to have the same function as ....030270 but is more expensive and rarer online?
It is expensive for what appears to be a simple filter. Are there any after market replacements for that part number?
Has the part actually changed from the ....030270 one shown above because of the water ingress issue?
Mark
  • MC-10252540-0001.pdf
This is all we know so far:
CABIN AIR FILTER
  1. INEOS Part Number: GRA-2G00-030270;
  2. RYCO Part Number: RCA451M. The dimensions are very close to the INEOS cabin air filter. Being a shade thicker it is a tight fit and harder to fit than the OEM, but it fits.
It is now 23.16 h here in Germany. So I have to wait till tomorrow. I will order one and tell you if it fits.
I copied and pasted that number from the Purnell Adventure Invoice. I will check against the Part number on the air filter box itself.
The box says GRA-3B02-008230. Table corrected.
The OEM Part number on the box was different also. I need to keep an eye on this and work out why there was a difference.
Try this one ADBP250076. should be direct fit This is MG cabin air filter
As suggested, I ordered the Blue Print ADBP 250076 filter for the MG. Unfortunately, the ADBP 250065 filter was delivered, but this wasn't a problem in the end, as it has the same dimensions and is also designed for an MG.
I compared the filter with the original filter used by INEOS. The slats themselves are the same height, but the plastic frame to which the slats are attached, is 5 mm higher than the one on the INEOS filter. For this reason, the Blue Print filter cannot be inserted into the holder under the dashboard of the INEOS. It doesn't fit!
What a shame, now we have to keep on looking for a suitable alternative to the original filter.Filter.jpeg
I bought these air, diesel, and oil filters for my Ineos Diesel. All filters, regardless of manufacturer and color of the box, are identical.
The BMW, UFI, and Bosch oil filters were made in Tunisia. The Mahle oil filter is from Bulgaria. The O-ring on the Mahle oil filter is attached slightly differently than on the other oil filters. However, I don't think this has any effect.
The AC is working better, can't believe how bad it was. Don't know if this helps but it is a pic looking up and you can see the empty slot. The clip on each end of the slot is easy to open. After you do it once it is easy to do.
