Front Drive Shaft Update
There is no question that a DC at one end will increase the angle of the CV at the pinion. Is this enough to cause an issue with the CV? Sounds like Dokatd has an answer to that question in the works. The issue of shaft length could be improved by changing the output flange of the transfer case so that the flange of the DC would bolt on directly without an adapter. Or the DC joint could have a custom designed flange that bolts directly to the TC output.
I believe the shaft in the photo was built by Sven. But he went dark after posting that.
hopefully didn't fall out of a closed hospital window...
The Black Box Big Brother thread
