Front Drive Shaft Update
My #2 question was more along the lines, that I don’t want to spend on a 3rd party fix only to have IG come out with a replacement under warranty.
My issue with the alternatives is that my main ‘trip’ is a two hour up and down with high speed (80MPH+ briefly), and a lot if engine braking. When I get to the destination, it is all medium speed and Offroad. The second half seems like it would be fine for the Agile alternative, the first maybe not so much.
Best solution for your use case (at the moment) is to not lift your truck. While failures have occurred in non-lifted trucks they are rare.
JMACX (Australia) just posted a video to YT stating they received federal approval for a GVM/GCM upgrade for both models up to 4.5t and 4” of lift. Would love to know how they’re addressing the drive shaft.
And yes, the QM looks great with a 4” lift on 35” tires.
View: https://youtu.be/Pqnd8yIrhwI?si=Gb9Zvo01rfEmga4I
What is the average cost of these repairs if outside warranty?
It depends if there is a secondary damage. In my case I needed new oil cooler lines, gearbox thermostat, prop shaft and gearbox oil. Ultimately a new gearbox, transfer box cables and heat shielding was needed. . You’ll see the gearbox has two impact marks this caused a hairline crack where one of the screws for the gearbox plastic pan connects.
Looks generally ok to me. The holes are located directly over the bearing pockets. To me it just looks like it cooked itself and the driver stopped for a moment or even parked it with glowing hot bearings. They melted out the relatively cheap and thin metal boot flange as those were the bearings close enough at the time it was stopped.
I was wondering what had caused the metal to look like it had exploded from the inside. I don't see a lot of escaped grease though.
I think I read where it was covered by warranty... maybe you also stated the cost if it wasn't but just in case, do you happen to know what it would have cost?
Covered by warranty but no idea of costs I’m afraid. Time off the road also a factor. Well over a month in total, including original failure and subsequently Waiting for parts and getting Ineos approval for repairs takes time.
I don’t even want to know how much this is going to cost.
1. A double cardan at the transfer case plus retention of a Rzeppa CV at the pinion is a potential solution. A twin double cardan is not, it will vibrate. A double cardan in combination with a single u-joint is not, it will vibrate.
2. No replacement shaft will be handled under warranty.
3. Regular inspection of the CVs will identify cracking early enough to prevent full failure of the CV joint. At first they will simply start to loose grease at which point they get replaced before joint failure that results from complete loss of lubrication.
Do you know of any DC/CV combo shafts out in the wild? I remember a guy building one a year ago and have messaged him about it but never heard back.
My concern is that the DC joint ends up increasing the angle at the pinion side and then that CV ends up having problems.
Just hang tight 😉
Its because it gets hot the second the boot tears, the grease leaves and melts the metal down. Seems insane it gets hot enough to melt in seconds. Not sure if the bad angle makes it worse, but probably does. Makes you appreciate how much more forgiveness U joints have.
It's because it gets hot the second the boot tears, the grease leaves and melts the metal down. Seems insane it gets hot enough to melt in seconds. Not sure if the bad angle makes it worse, but probably does. Makes you appreciate how much more forgiveness U joints have.
I certainly have not seen this. I have driven hundreds of miles on a torn boot. It takes awhile to go nuclear. The one above doesn't even appear to have a torn boot. It certainly might and the photo just doesn't clearly show it, but I'm not seeing any evidence of it including grease spray. I suspect this one was poorly greased from the factory.
The heavier angle on lifted trucks certainly contributes to more heat of course.
It doesn't take more than a few seconds to turn a rapidly spinning drill bit red hot if you don't lube up.
This is incorrect - if the driveshaft fails on an unmodified (not lifted) Grenadier, it will be covered under warranty.
I was not referring to a replacement OEM shaft. And neither was the original post to which I was replying. "2. While I don’t want to have a front drive shaft fail, I also don’t want to spend a few grand on something that might be handled under warranty (maybe)." Meaning why spend money on an aftermarket shaft if sticking with OEM means it might be covered under warranty.
It goes without saying that an original shaft or replacement OEM shaft on an unlifted vehicle will be covered under warranty. On a lifted vehicle warranty seems to be a spin of the roulette wheel.
Wasn't there a guy who got denied based on the way he "Drove" his vehicle. He had a bone stock truck and I believe he was in Europe.
There is no question that a DC at one end will increase the angle of the CV at the pinion. Is this enough to cause an issue with the CV? Sounds like Dokatd has an answer to that question in the works. The issue of shaft length could be improved by changing the output flange of the transfer case so that the flange of the DC would bolt on directly without an adapter. Or the DC joint could have a custom designed flange that bolts directly to the TC output.
I believe the shaft in the photo was built by Sven. But he went dark after posting it.
