Front Drive Shaft Update
My #2 question was more along the lines, that I don’t want to spend on a 3rd party fix only to have IG come out with a replacement under warranty.
My issue with the alternatives is that my main ‘trip’ is a two hour up and down with high speed (80MPH+ briefly), and a lot if engine braking. When I get to the destination, it is all medium speed and Offroad. The second half seems like it would be fine for the Agile alternative, the first maybe not so much.
Best solution for your use case (at the moment) is to not lift your truck. While failures have occurred in non-lifted trucks they are rare.
JMACX (Australia) just posted a video to YT stating they received federal approval for a GVM/GCM upgrade for both models up to 4.5t and 4” of lift. Would love to know how they’re addressing the drive shaft.
And yes, the QM looks great with a 4” lift on 35” tires.
View: https://youtu.be/Pqnd8yIrhwI?si=Gb9Zvo01rfEmga4I
What is the average cost of these repairs if outside warranty?
It depends if there is a secondary damage. In my case I needed new oil cooler lines, gearbox thermostat, prop shaft and gearbox oil. Ultimately a new gearbox, transfer box cables and heat shielding was needed. . You’ll see the gearbox has two impact marks this caused a hairline crack where one of the screws for the gearbox plastic pan connects.
Looks generally ok to me. The holes are located directly over the bearing pockets. To me it just looks like it cooked itself and the driver stopped for a moment or even parked it with glowing hot bearings. They melted out the relatively cheap and thin metal boot flange as those were the bearings close enough at the time it was stopped.
I was wondering what had caused the metal to look like it had exploded from the inside. I don't see a lot of escaped grease though.
I think I read where it was covered by warranty... maybe you also stated the cost if it wasn't but just in case, do you happen to know what it would have cost?
Covered by warranty but no idea of costs I’m afraid. Time off the road also a factor. Well over a month in total, including original failure and subsequently Waiting for parts and getting Ineos approval for repairs takes time.
