Front Drive Shaft Update
I’m sorry this happened to you! Could I ask what exact Fox shocks you have on the front?
I’m just curious to find their extended length in comparison to the factory shock length as it acts as a bit of a limiting strap and might protect the boot.
Fox 2.5 performance elite. Same length as stock.
Here is what I have at the moment. This last joint was caught at 5000miles with only a minor tear. This allowed me to remove the boot and compare to the last one I pulled The boot is most certainly being pinched at the extent of full travel even with stock length shocks. You can clearly see the wear on the boot and even the machine marks from the shaft telegraphing into the rubber. The pinch is light, and gently extrudes the rubber boot to the point that the rubber is super thin at the tear point. Eventually the boot can't hang on any longer and finally tears The tear can propagate around the thin portion of the boot or start to move out to the clamp ring depending on a few factors.
Note, the factory and Terra boot maintain full rubber thickness in the area where the boot tears. Over time the boot thins out from a pinching actions. You can clearly see in my pics the boot thins out to almost paper thin. Those who never go Offroad or those who drive pretty smooth roads without whoops or big bumps are likely going to see far more mileage per joint than those that actually use the truck for its intended purpose. People that drive the highway are constantly hitting whoops in the road that cause pinching. The only sure thing right now is to put limiting straps on to prevent the last 1" or so of travel.
Lifts just don’t play nice with these trucks.
I was talking to Jay Couch as my flat tray and half box is ready. Sounds like another portal option will be offered. He is working on it and initially we might have two different height options.
That rubber gets thin there doesn't it... Thanks for the great work on this detailed breakdown!!!
I will post this chart you made again as it has been really helpful for me. FWIW the Agile Fox shocks have a nearly identical extension and compression length as the stock SACHS shocks.
I weighed all the points in this discussion when choosing to get new shocks and springs. I ended up with Koni Raid shocks because of how robust they are, and the extended length is in believe the same if not shorter than stock. I also initially bought the EU lift, 30mm, but haven’t installed that for fear of harming the boot.
On a side note regarding Caster, there has to be something to running the caster as low as possible. I’m at 1.5° caster and at 16k miles, stock suspension, and checked the boot last night and looks new, albeit a bit dirty. I’m considering going to a lower caster angle in the future as I find the “terrible steering” not too bad and what I’d expect from a truck with this front end architecture. One of the members of the NorCal Grenadier group is approaching 75k miles with a 2.5” lift and metalcloak adjustable suspension, at .7° caster and still on the original CV.
Granted, lowering the caster makes for worse highway handling, but I think that’s a fair trade off of potentially longer CV service life.
It is not the end of the world indeed; in Land Rover solid-axle past, each inch of suspension lift took away 1.1 of a degree of caster, with 3 deg factory setting. Most everyone taking their trucks off pavement had at least 2" of lift, leaving barely 0.8. I drove my D1 like that for a decade and a half; it was squirrelly, didn't have a good return to center, and you wouldn't want to take it much past 80 mph. But it was somewhat livable.
How much range do we get with the Grenadier for caster angle?
I believe the factory range is 1.25°-2.2°, with 2.0° being the nominal number. I think I’m going to lower mine all the way to 1.25° and see if that too negatively affects the handling or if it’s livable for daily use. I’d really love to install the 30mm eibach lift I have sitting in my garage.
View attachment 7919625View attachment 7919632View attachment 7919627View attachment 7919637View attachment 7919639View attachment 7919640
Useful post, thanks for sharing.
Are you suggesting the boot needs to be more like this:
Rather than this?
The takeaway is that the OEM front shocks allow just enough droop so that the boot comes into light contact with the surrounding metal housing/flange. Not enough contact to immediately destroy the boot but enough that over time the boot is thinned out until eventually it fails once the rubber has become too thin. Given this, any replacement shocks with an extended length longer than OEM will cause the boot to fail more rapidly as the resulting contact between the boot and the metal housing will be greater even if used with factory springs. Taller springs installed as a lift will not increase the boot-flange contact but it will cause the joint to run at a higher angle resulting in more stress on the boot which accelerates degradation of the thinning material.
For owners considering a lift and who want to maximize the life of the CV boot, do not install shocks with a longer extended length. King Shocks for this reason are a definite no go as they are 28.54mm longer than the OEM length of 590mm. The Koni shocks for the Grenadier match the length of the OEM shocks from Sachs. It would be good to know the shock lengths from Fox, Radflo, Eibach, Dobinson, Reiger, Nimbus, Metal Cloak, Owl etc. Most are likely longer than OEM. See post below for detailed shock lengths.
Did you cut a stock unused boot as a baseline? The material at the bend may be deliberately thinner to prevent the outer edge stretching to begin with.
I dunno doing fine on my kings for past 10k miles thus far, so not sure if there is a good set of data to compare between all the shocks.
A table of extended shock lengths for the Grenadier. Use of shocks longer than the OE Sachs models will very likely shorten the lifespan of the front driveshaft CV boot. Fox, Koni and maybe Radflo are the only shocks with published lengths equal to or less than the Sach units.
Sach OEM - 590mm
Dobinson IMS - 635mm (+45mm)
Dobinson MRR - unknown
Eibach - Unknown
Fox 2.0 - 587.25mm (-2.75)
Fox 2.5 - 589.79mm (-.21mm)
King - 618.54mm (+28.54)
Koni - 590mm (OEM match)
Metal Cloak - 622.3mm (+32.3)
Nimbus - Unknown
Ohlins - Unknown
Owl - 618.54mm (+28.54, same as King)
Radflo - OE length per Radflo, actual length unknown (OEM match?)
Reiger - Unknown
A table of extended shock lengths for the Grenadier. Use of shocks longer than the OE Sachs models will very likely shorten the lifespan of the front driveshaft CV boot. Fox and Koni are the only shocks with published lengths equal to or less than the Sach units.
Sach OEM - 590mm
Eibach - Unknown
Nimbus - Unknown
Ohlins - Unknown
Reiger - Unknown
I have radflo which is OEM. My left side is 1.76 degree caster -0.15 camber and right side is 1.88 degree caster and -0.58 camber. The boot is still looking new after 8k of driving with 60% on road and 40% off road.
Sach OEM - 590mm
Eibach - Unknown
Nimbus - Unknown
Ohlins - Unknown
Reiger - Unknown
I understand there is a list of shocks and their size, but how often does it fail more than others when they are longer? What data exists to show that Xmm longer reduces the lifespan by Y?
Might it be worth the cost to sacrifice a new unused TerraFlex CV to cut a cross section in the boot to compare it with the failed boot.
Simple geometry dictates that longer shocks will bring the boot flange closer to the shaft resulting in more pinching of the boot material. The only way to test this empirically would be to mount every variant of available shocks and measure the gap between the flange and the shaft at full droop. For a statistical failure analysis that would require running every shock on multiple vehicles over thousands of miles. That data is never going to be available, but this seems hardly necessary given the intuitive nature of the problem. The OE shock allows enough travel to cause boot failure because of the high CV angle. Any shock of longer length will accelerate this failure by increasing the CV angle even more. What is the value in knowing for example that 20mm of extra length will cause the boot to fail 5000 miles earlier. The solution is to reduce the CV angle by changing the geometry of the front axle housing.
Simple geometry dictates that longer shocks will bring the boot flange closer to the shaft resulting in more pinching of the boot material. The only way to test this empirically would be to mount every variant of available shocks and measure the gap between the flange and the shaft at full droop. But this seems hardly necessary given the intuitive nature of the problem.
Yeah not arguing the problem or the fact that more movement on the boot is death to the boot, just curious if we have data that supports such findings as well. I'm lifted with kings and I've now outlasted a report on this post of a OEM failure..... So does it really matter at this point or is the problem just actually widespread and a ticking clock heading to zero no matter what is fitted?
This is the likely outcome if driven with intent in true off road conditions or towing regularly. The highly variable nature of the boot failures, whether lifted or otherwise, is vexing but in the end Ineos just screwed the pooch with this axle design and we have to deal with the consequences.
I'm reading my service for the warranty front axle replacement, and apparently they found damage to driveshaft boot and replaced the driveshaft. I checked at about 20k and it was in for service at 22k.
Never had this offroad or flexed it. So as DD it went out at between 20 and 22k. (miles)
