Front Drive Shaft Update
One thing is certain: the only cv joint that heats up significantly compared to the others is the one that also creates the most problems.
You aren't wrong, but I don't believe we have seen a variance in failure from different climates.
Anyone fit adjustable control arms and see a difference in pinion angle worth mentioning? I have a QM with 1.7” lift.
There's plenty of caster adjustment in the factory suspension, no need at all in adjustable control arms.
Besides... you tweak the caster, handling changes are immediate and obvious, but effect on the driveshaft will or will not materialize in several thousand miles. I don't think there's anyone with that much patience in this crowd.
I tried to contact Dana but couldn't find any way to do so. I can't find an email address or contact form.
However, I did find their website with spare parts: https://www.danaaftermarket.com/Automotive/Automotive-Driveshaft/Drive-Shaft-CV-Joint
Can anyone identify which CV joint is ours? I would like to try to get an original one and compare it with a Teraflex that I already have. Ineos is not among the vehicles offered...
Try to isolate any that have the correct mounting parameters, then compare boot design.
It appears none of the listed parts are for the Wrangler JL/JT or the Grenadier. I clicked through them all and none were for these models. They list the CV for the Wrangler JK which is an older model but not the current JL version.
The driveshafts are made by Spicer Ayra Cardan, not actually Dana, but a sub-division. You might find something on a web search.
This is a brand new shaft from Ineos, less than 500 miles. Photo taken today after a trip to Anza Borrego for 1.5 days. Look at all the wear in the boot at the differential.
King 1.5” lift and adjustable shocks.
That is some crazy shit honestly...... Sad just sad.
My last shaft lasted 10k, mostly stock. I was on a 2” Eibach lift for maybe 1000 miles and that did it.
Went to Kings and here we are in 500 miles. 1 trip and really just 1 day of wheeling. Hell, you can hardly even call it that; most of it was stuff a Subaru could do.
I don’t understand how some with bigger lifts than I have can reach 7k unless it’s kept only on the street. Any sort of flex and you’re in trouble.
Who wants to sell me their Agile or Sven driveshaft?
View attachment 7919500This is a brand new shaft from Ineos, less than 500 miles. Photo taken today after a trip to Anza Borrego for 1.5 days. Look at all the wear in the boot at the differential.
Isn’t that just the paraffin coating peeling off?
All around its is just crazy.... I'm about to hit 10k full on my 2.5" kings shocks... I put it on right about 1200 miles and I'm nearing 11k. Everything looks okay thus far, I've been to Moab three times and did a lot out in CO. I also cruise 80mph ALOT.... just waiting for my day I guess.
Here’s info on the coating. You are probably only seeing the cracks in the coating. The unnatural geometric lines strongly hint that’s the case:
I have no idea why they would need such coatings, today the rubber better damn well be TPEE or we are all in trouble anyway.
Who knows what it is exactly, my assumption is it's from spraying the shaft. Could even be a light coat of paint. Mine has been gone for ages so I can't recall the exact makeup.
mine fell all over my face when I was changing the transfer case fluid. I graced it with my hand and the coating sprinkled down.
