Front Drive Shaft Update
Beat me to it. I have had larger version of these spicer non greasable truck slip joints do the same piston thing. Pull the Uj back and it will create a vacuum then retract or pressurise and expand. Pretty sure because of being non serviceable Spicer Life series SPL slip joints are not vented. Not really an issue with bolted flanges but a real pain when trying to remove and fit them.
Would Spirolock suit this application better then a circlip
Interesting, I didn't know about them.
I see they're generally used on pistons, making contact on the outside. Can they also be used on the inside, as in our case?
In Europe, however, they seem impossible to find. Where can I find them in the size needed for our driveshaft?
The spiral lock ring can be used on an outside or inside locking groove, common for to be recessed into a gear and retaining parts onto shafts or in housings. It may be better to search spiral retaining rings as there are various brands. Spiral rings like circlips are available for various thrust loads different brands may have different materials in their products. Added some info from one brand.
Never really looked into circlip specs before, lost count how many I have removed and fitted from .5" to 15" over the years.
Not sure what the Ineos shaft groove diameter is but a 25mm external DIN circlip should take around thrust 1600kg 3500lb force before failure in a square edge groove and about a quarter of that if the edge is tapered. I doubt a good slip joint is generating those thrust loads even with rotational force of the shaft.
Does the Teraflex cv need to be shimmed between the circlip and hub to stop hammering, shock loading the circlip?
Got home after 7 weeks away so got underneath and tried the Agile shaft, went for a 100km drive half beach and sand, half highway, removed it.
Kudos to Agile for having a go but as mentioned by others it’s not a long term driving fix.
So put a new Rzeppa on transfer side and refitted, went for a test drive all smooth… crawled underneath to retorque and found front diff side now gone…🤦🏻‍♂️ and I inspected it… obviously not well…
So we wait for another joint…
Back to old faithful…View attachment 7911362
….. and Ineos won’t even acknowledge this is an issue. At least with the HVAC they will say that it doesn’t work well and there really isn’t anything they can do about it.
What is frustrating is that there is an engineering solution. It won’t be cheap but it can be fixed. Yet they continue to build new cars with the exact same shit design. All they are doing is costing themselves more in the long run. Fix it before they produce more and then retrofit the existing cars before they have to do it to 100,000 of them.
