Front Drive Shaft Update
Beat me to it. I have had larger version of these spicer non greasable truck slip joints do the same piston thing. Pull the Uj back and it will create a vacuum then retract or pressurise and expand. Pretty sure because of being non serviceable Spicer Life series SPL slip joints are not vented. Not really an issue with bolted flanges but a real pain when trying to remove and fit them.
Would Spirolock suit this application better then a circlip
Interesting, I didn't know about them.
I see they're generally used on pistons, making contact on the outside. Can they also be used on the inside, as in our case?
In Europe, however, they seem impossible to find. Where can I find them in the size needed for our driveshaft?
The spiral lock ring can be used on an outside or inside locking groove, common for to be recessed into a gear and retaining parts onto shafts or in housings. It may be better to search spiral retaining rings as there are various brands. Spiral rings like circlips are available for various thrust loads different brands may have different materials in their products. Added some info from one brand.
Never really looked into circlip specs before, lost count how many I have removed and fitted from .5" to 15" over the years.
Not sure what the Ineos shaft groove diameter is but a 25mm external DIN circlip should take around thrust 1600kg 3500lb force before failure in a square edge groove and about a quarter of that if the edge is tapered. I doubt a good slip joint is generating those thrust loads even with rotational force of the shaft.
Does the Teraflex cv need to be shimmed between the circlip and hub to stop hammering, shock loading the circlip?
Got home after 7 weeks away so got underneath and tried the Agile shaft, went for a 100km drive half beach and sand, half highway, removed it.
Kudos to Agile for having a go but as mentioned by others it’s not a long term driving fix.
So put a new Rzeppa on transfer side and refitted, went for a test drive all smooth… crawled underneath to retorque and found front diff side now gone…🤦🏻‍♂️ and I inspected it… obviously not well…
So we wait for another joint…
Back to old faithful…View attachment 7911362
….. and Ineos won’t even acknowledge this is an issue. At least with the HVAC they will say that it doesn’t work well and there really isn’t anything they can do about it.
What is frustrating is that there is an engineering solution. It won’t be cheap but it can be fixed. Yet they continue to build new cars with the exact same shit design. All they are doing is costing themselves more in the long run. Fix it before they produce more and then retrofit the existing cars before they have to do it to 100,000 of them.
Ok, I don’t even know what an “Rzeppa joint” is, but I am willing to crawl under a vehicle-on a daily basis if need be-to look for trouble. Is there an inspection procedure that the average owner can follow (without tools or a lift) to catch and forestall any of these known failure modes?.
Yes. Grab a flashlight and check both ends of the front driveshaft for tears in rubber and leaking grease.
Who wants to start an excel spreadsheet that indicates build date/vin, milage, lift, model and when the boot has torn. Maybe they have changed something on the newer models and our issue is with older models. When I say fix, meaning a difference in boot material or under the boot.
I would assume if anything with the driveshaft was upgraded or changed we would most likely notice it with a superseded part number. It would have to be flagged as a new part from a logistics, inventory, batch production, failure tracking standpoint and attached to VINs where the new upgraded part was installed. It would be poor business practice and outright negligence not to do so.
I don’t think anything has changed, after inspecting a brand new vehicle, some fail early, some with lift some without. Mine did 56000kms and 45000kms with a lift. Most driving on HWY at speed.
And yes a crap design… New Rzeppa takes an hour once you have done it. But quite the Achilles heel.
Looking forward to a permanent reliable fix.
A very informative vid. of a chap replacing a Ford Everest drive shaft CV joint (which shares commonality with Jeep Cherokee). Sound familiar? He performs the task in a caravan park, on his back under the vehicle. He takes it step by step, shows in detail what's involved... e.g socket sizes, circlip pliers, soft face hammer etc.
Now I know what to expect!!
View: https://youtu.be/9-MgpY23NZ0?si=hfY_ADoKUAUgxLsN
The hardest part would be finding a vacancy in a caravan park 😉
I have attached the instructions that Teraflex provide as another example of how to proceed with replacing a driveshaft CV joint. Note the 29 ft.lb bolt torque is from Teraflex not Ineos. Ineos has a weird part wrench-angle part final-torque method to secure the bolts. I'll try to access it later and update this post if the workshop manual likes me today.
Mixed messages on the forum about the effort needed to remove the factory end cap. Some say you need an angle grinder, presumably to remove some crimped edges, others say it fell off easy/after a tap from a knockometer 🔨 I think @Dokatd has commented on this.
Plan for the worst, hope for the best 👍
Edit: Link to Teraflex replacement video
View: https://youtu.be/gxw_iO9zuRM?si=c5nk5g26jXFP7mYe
I just knocked the end caps off with a flat screwdriver and a hammer. It is like prying open a can.
I'm curious to know what the official Ineos tightening torque is
I watched the video, and it seems to be exactly my experience, except that the new joint in the video was installed with a hammer, while in my case, the Teraflex joint had no friction whatsoever. I repeat, this places the entire load of the propshaft movement on the C-clip, which isn't designed for such stress, inevitably leading to failure. I've currently purchased a new front driveshaft from Ineos, which I'll install as soon as it arrives. When the boot breaks again (which I assume will unfortunately happen), I'll replace just the boot with the Teraflex one, while keeping the original joint.
I’m pretty sure I have roto-flex coupling LR used on late 90’s D1’s and RRC’s. It’s held up fine on my LWB w/EAS.
