Front Drive Shaft Update
In the thread You mentioned the discussion is about different joints, from the JL oder the JK, as far as I'm concerned...
I ordered the joint for the JK modells, Teraflex 1744014, suppossed te be the right one.
It is not installed in the moment but I was thinking if it might redude the vibrations.
Regards
You have the wrong CV. You need the one for the JL
Regards
Sorry I was trying to be helpful by directing to you to another thread that I thought may have been usefull 🙏🏼
That was helpfull indeed, let me double check I ordered the right one!
The only trouble I can see, as I said in the other thread, if you change the C.V joint and you have a total failure you are in a world of trouble as possibly a new gearbox required plus other damage as the prop flails around. Unlikely to happen and you should hear if it’s gradually failing. Ineos warranty wouldn’t apply if an aftermarket CV joint had been fitted though. Mine failed with no warning but that was supposedly a Circlip failure although I’ll never know for sure.
Good to know, but do You think if Your prop shaft flies around somebody will find out that the joint was aftermarket? :unsure:
Regards Sauerländer
Regards Sauerländer
That I don’t know as I don’t know if there any really distinguishable differences. Personally I won’t take the chance.
Regards Sauerländer
Well, the shaft is two pieces and you only "need" to change the T-case side. So if the back half of the shaft is "missing" then who would know. Just sayin. Could have even happened when the tow truck picked it up and transported. Who knows how these things really work. 🤷🏻
That said, they don't fly off unless you failed to properly install the C-clip or neglected to change a failed joint. The joints fail slowly and noisily. A failed boot is just the start. The joint will get progressively louder until it finally chews itself up. That takes some time and many miles.
Today, less than 1,000 km after installing the 1.2-inch 😶 Eibach front springs to level the front and rear, I discovered a broken front transfer-side shaft bellows. I already had a new Teraflex 1745000 joint at home, but the installation is proving much more complicated than expected: the transfer-side shaft refused to come off, and neither did the joint itself.
I'll try to finish installing the new joint tomorrow, but are there any aftermarket universal joint or double universal joint shafts that I've tested that don't vibrate like CVs? If I remember correctly, they were all vibrating.
Did they disconnect the drive shaft when installing the springs? Having damage after only 1,000 km with just a 1.2-inch lift seems a bit too soon. The damage may have occurred during the spring installation.
Haven’t there been failures of the drive shaft and boot on standard height vehicles with the lifted ones just exacerbating the problems from the design
