Front Drive Shaft Update
In the thread You mentioned the discussion is about different joints, from the JL oder the JK, as far as I'm concerned...
I ordered the joint for the JK modells, Teraflex 1744014, suppossed te be the right one.
It is not installed in the moment but I was thinking if it might redude the vibrations.
Regards
You have the wrong CV. You need the one for the JL
Regards
Sorry I was trying to be helpful by directing to you to another thread that I thought may have been usefull 🙏🏼
That was helpfull indeed, let me double check I ordered the right one!
The only trouble I can see, as I said in the other thread, if you change the C.V joint and you have a total failure you are in a world of trouble as possibly a new gearbox required plus other damage as the prop flails around. Unlikely to happen and you should hear if it’s gradually failing. Ineos warranty wouldn’t apply if an aftermarket CV joint had been fitted though. Mine failed with no warning but that was supposedly a Circlip failure although I’ll never know for sure.
