What is your garage door height?Measurements related question I guess. Grenadier height is listed a hair above 80 inches. My garage height is 81 inch. Will it fit?
2.036mm is the given height for the Gren.. My grenadier lair has an electric roller shutter and I’ve only got 2.060mm or c 81 inches clearance. Worse case, I’ll be letting some air out of the tyres. Will be a faff but the shed only went up last year and I put a compressor in so it’ll be an excuse to use it.What is your garage door height?
I presume you mean metres measurement of 2.06 and 2.036. Therefore you should have 24mm clearance ( good old fashion 1") all going to depend on it being level ground. I'd make sure someone checks the first few times you try it.2.036mm is the given height for the Gren.. My grenadier lair has an electric roller shutter and I’ve only got 2.060mm or c 81 inches clearance. Worse case, I’ll be letting some air out of the tyres. Will be a faff but the shed only went up last year and I put a compressor in so it’ll be an excuse to use it.
Keep the fuel tank full and put on some weight.I presume you mean metres measurement of 2.06 and 2.036. Therefore you should have 24mm clearance ( good old fashion 1") all going to depend on it being level ground. I'd make sure someone checks the first few times you try it.
one of life's great maximsKeep the fuel tank full and put on some weight.
I will have to buy a new house with adequate garage, because I don't have a compressor2.036mm is the given height for the Gren.. My grenadier lair has an electric roller shutter and I’ve only got 2.060mm or c 81 inches clearance. Worse case, I’ll be letting some air out of the tyres. Will be a faff but the shed only went up last year and I put a compressor in so it’ll be an excuse to use it.
Hang your head in shame Jean…. EBay will sort you right out with the essentials…I will have to buy a new house with adequate garage, because I don't have a compressor![]()
That is frightening cheap, I don't know how the Chinese do it. Do you think it lasts beyond one operational cycle?Hang your head in shame Jean…. EBay will sort you right out with the essentials…
SGS SC50H 50L 9.6CFM 2.5HP Air Compressor for sale online | eBay
Find many great new & used options and get the best deals for SGS SC50H 50L 9.6CFM 2.5HP Air Compressor at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
cheap as chips.
I've seen two dimensions for overall height: 2036mm and 2050mm .. am wondering if it depends on tyre size/pressure. My garage door clearance is 2065mm so no roof bars or rack. It's actually just 100mm longer with the spare wheel than my Santa Fe... but 1 ton heavier!! So I have to think about point loadings on the wooden floor of the garage deckmy garage was built to fit the Defender. So it’s 2,05 meters in height under the open gate. That’s sufficient for the Grenadier but I do not have to think about fitting a roof rack.
At least my garage floor is concrete based on rocks…I've seen two dimensions for overall height: 2036mm and 2050mm .. am wondering if it depends on tyre size/pressure. My garage door clearance is 2065mm so no roof bars or rack. It's actually just 100mm longer with the spare wheel than my Santa Fe... but 1 ton heavier!! So I have to think about point loadings on the wooden floor of the garage deck![]()
what's the partial coloured US map on the LH side signify?All this talk about fitting into the garage...
The day I brought my RAM home, I had to hang out the door and think small to see if it would fit in the garage. Cleared the door by less than an inch to the top of the shark fin antennaBut I had to shimmy sideways past the cabinets in front of it. This was with the tiny 33" stock tires. Once the 37s went on? Nope...outside doggy.
Couple this with the Sequoia not fitting in the garage (even without the RTT on it, it would be too tall), and our trailer not fitting, it was time for a new garage. 10x10 roll-ups, 18'x71'x15' peak with 12' sidewalls. So if anyone is in the area of Front Royal, VA and needs a place to work on their Grenny...come on by
Thanks...it's my home next to my home that houses my homes away from homewhat's the partial coloured US map on the LH side signify?
nice workshop by the way.
excellent - good luck filling in the blanksThanks...it's my home next to my home that houses my homes away from home
That map is the states we've visited in that vehicle. And, no, "just driving through" doesn't qualify![]()
Funny enough...I hope I don't! Because if I do, it means the Grenny thing didn't work out in time as this is the vehicle it'll replace!excellent - good luck filling in the blanks![]()
Air down to garage it, then pump up when you pull out?Measurements related question I guess. Grenadier height is listed a hair above 80 inches. My garage height is 81 inch. Will it fit?
How is it a challenge mate? Just sell the house and buy one more suitable.I also have a View attachment 7808295weird protrusion on the left side which is below Grenadier height. It will be a challenge...
