Can't find phone holder image
Global Grenadier 76
8:07 AM
Hello all - truth be told, our search function isn't the best. This is for a variety of reasons, but it can be quite frustrating when one is looking for something and cannot find it. Hence this post!
Somewhere here there was a photo of a phone holder/tray that sat above the infotainment dial on the consol. Can any of you direct me to that image?
Think you're looking for more of a storage cubby but I've seen this one in the past.
One word of caution, coming from a Cannonball Run guy, I tend to think of everything in a vehicle as a potential projectile especially when airbags are in the vicinity. I try to keep anything that could go flying mounted low... taking an iPhone to the knee vs the head seems preferable. Not a huge deal when off road at low speed, but assuming you daily the truck at highway speeds on occasion it's something to think about.
Thanks but that's not it. It was a raised "tray" that covered the infotainment dial and buttons. It's driving me nuts.
This one?
Something similar on this.
This maybe?
Sounds like something STREK might sell
Just took a quick peak at their website and couldn't see anything.
I had designed a box to block my dogs from stepping on the buttons that one version also had a tray. I think I posted on FB. I don't have a picture as I gave it away to someone. Here is the STL file. I guess I should get around to putting it in resources?
I put the STL in Resources.
This is very nice but not what I'm searching for. Maybe I imagined it. As I recall (or saw in a state of delirium) it was more like a frame with a ledge the phone sat on. If the phone was not there you had access to the rotary dial and buttons.
That's it - THANK YOU!
But... I only want the phone bit (no need for cup holder part. I just got access to Fusion 360 but the knowledge from my CAD classes in the early 90s is long gone (and would be way outdated even if I could recall anything)!
I used to know CAD well in the 90's, I really would like to learn to use a real program like OnShape. But until then I use the simplistic TinkerCAD. See what you think of this. I whacked the cupholder off and radiused the corners.
Hat's off to @IG Pop
Yea, that basically it. But there's another fly in the ointment. I have the grenadierusa cup holder and it has two "protective" metal protrusions. But, if it was solid there could be recesses in the base into which the bars would slot.
I am in a 6 hour Teams meeting, that is boring. So this is a good use of my time.
Some disclaimers
- I have the same Grenadier USA cupholder. But my Grenadier is at Red Nolan for service, so the dimensions may be off. I do think they are good. Give the template a try.
Template (1mm thick)
Final
Note - the loaner I am driving is stock, I had totally forgotten how small the cup holders are. Tiny...
That looks great. If the base was raised would it possible to hide the bars all together?
Edit - maybe I could use an antislip rubber sheet and cut it to fit. Or print a separate "bed" and glue on.
I use this self adhesive rubber sheet to put on the bottom of things, and trim it with a scalpel once it is stuck on.
