Bison Gear - 4x4 & Overlanding Accessories
We're Bison Gear, and our mission is to provide you with the absolute best gear for your next thrilling journey. 🏞
Currently, our focus is on the remarkable INEOS Grenadier, recognized as the ultimate platform for overlanders.
First top-notch products are already out in the market, specially designed to enhance your INEOS experience.
But that's just the beginning! 🚀 Soon, we'll be rolling out an entire range of premium gear, meticulously crafted for your INEOS Grenadier.
Stay ahead of the adventure game with Bison Gear – where quality meets exploration! 🏕🔧
What are people’s expectations around exterior bolts in the BG Roof Rack?
Leaving the Grenny out for the winter (Central Europe) these bolts in particular seem to have suffered quite a lot of rust.
Another point I wanted to get some opinions on is the wind deflector on the BG roof rack. Around 110 km/h the deflector starts to vibrate.
Looks to me that the ring is fine and the bolt itself is not fit for outside use. A lot of these are Chinese junk. Your best bet is to find something marketed as 316 stainless. I found some on Amazon that have worked for me. Unless I'm actually using them, I take mine off too.
It also looks like you should be using a washer with your eye bolt. I don't see a lot of metal on top interfacing with the rail.
Just installed my Bison Gear Left and right Baskets.
Very fast shipping (poland belgium)
Very well packed, with screws and manual.
Very easy install
Very nice fit, good use of that lost space.
Only negative is that under the left basket the plastic cover, to get access to the crank, is very difficult to get back on when the basket on the top.
The way i did get it back on, is by reaching with my right hand under the cover and get the pins in place to click them in the openings. A bit tricky, so will probably not use that extra space there.
How wide is the storage for the basket on the right? Wondering if I could fit a REDARC inverter in the basket.
Hi Guys!
Has anyone fitted the new Bush Company LX27 lightweight roof tent (now with East/West tent foot extrusions) to a BG 3/4 roof rack (RR-GRND-23) and possibly also fitted the 270° Bush Co XT Mk2 using the Awning to Tent bkt. 4RTAABL? Does it match?
Cheers!
Hi, I have the Bison Gear 3/4 rack and am trying to fit the camp table. It was shipped with instructions for the internal Molle panel for a Ford Bronco and these T bolts. Shown here next to the t bolts from the accessory trays that go into the rack. Are these are the wrong ones, or am I being extremely stupid, I’m just going to use the spares of the ones I have because I can get them into the tracks. They also corrode easily, so will be swapping them all out for stainless.
Hi, yep, same one I found. However the Grenadier table is mounted at the rear as per the photos on the website, not into the side, which these instructions are for. My rack doesn’t have the panel on the side they talk about using and the fittings to re-use. And the T slots provided are huge, unless you’re supposed to remove the sides of the rack and slide them in but I doubt they’ll fit. I’ve mounted it now using the smaller T bolt from the accessory tray.
Hi, Bison Gear here!
Just dropping in with the referral code some of you were asking about: INEOS10OFF
If you're looking to spice up your INEOS build, now’s a great time — this code gives you a -10% discount, valid once per order, works on all Grenadier compatible accessories - valid for 2 weeks from now on.
It’s our way of saying thanks for all the support and kind words you’ve shared about our brand.
As always, if you need anything or have questions, feel free to reach out. We’ve got your back!
