Bison Gear - 4x4 & Overlanding Accessories
We're Bison Gear, and our mission is to provide you with the absolute best gear for your next thrilling journey. 🏞
Currently, our focus is on the remarkable INEOS Grenadier, recognized as the ultimate platform for overlanders.
First top-notch products are already out in the market, specially designed to enhance your INEOS experience.
But that's just the beginning! 🚀 Soon, we'll be rolling out an entire range of premium gear, meticulously crafted for your INEOS Grenadier.
Stay ahead of the adventure game with Bison Gear – where quality meets exploration! 🏕🔧
I'm interested to hear how the economy (tight git) is affected as I would like to get one ready for roof tent/retirement.
Hi Krabby. I'm curious to know if you've received your Bison Gear roof rack yet. If you received it already, have you measured the overall height of the truck with the rack? I'm researching different options, but my garage is limited to 84 inches. Any information is greatly appreciated!
Hi Texas Grenadier, I very accurately measured my Trailmaster Grenadier that was on stock 17" alloy's with KO2 tires, has a front winch and side steps.
Ineos says in their brochure that the Grenadier is 80.7" tall, however my Grenadier is exactly 78.9" tall from the ground to the top of the plastic strips on the roof.
I recommend you contact Bison or find someone on the forum to measure how high the rack sets above the plastic roof strips and then add that measurement
to 78.9". I think you will find you have plenty of clearance if your garage clearance is 84". If you are looking for a stout low profile rack, you may want to consider the Leitner 3/4 rack. Extreme build quality including the brackets that are made of solid CNC machined billet 6061 Aluminum. The rack height is just 2.4" over the plastic strips on the roof. DaBull
DaBull, this is excellent information. Really appreciate it... It looks like I will have plenty of clearance. I will check Leitner for sure. Take care!
Love the interior above head storage option! Looks so handy
I am installing the roof rack and one of the 12 factory bolts that attach the roof bars will not budge. The other 11 came out easily but this 12th one won’t budge and after 3 tries I gave up in case of damaging the bolt further - any advice on how to deal with this ?
I would give the bolt a good spray with a shock freezing spray
Something like this
Something like this
Thanks @landmannnn - will hunt something similar down or take it to dealer or workshop to get it dealt with professionally. Looking forward to the day when I get to put the 6th bracket in to place.
Until then:
The bison 3/4 rack adds 6cm to the overall height of the vehicle. The wind noise is basically nothing upto 50mph but beyond that you can slightly hear it but nothing serious.
Y
Worked at treat @landmannnn - Thanks.
Quick question perhaps for @Bison-Gear or anyone else with a Bison roof rack: would the Front Runner BLACK TIE DOWN RINGS / EYE NUTS work?
Yes
The Bison gear rails do take M8 T bolts which is what the Frontrunner ones are.
However to insert the T bolts you will have to enlarge the holes that Bison have drilled in the aluminium profile.
Saying that, maybe not all T bolts are the same, the T bolts I bought wouldn't quite insert without some modification.
By the way, such as Amazon will sell you Eye bolts for T track for much lower cost.
Y
Yes
Hi @landmannnn - I suspect but please correct me that if the system is using M8 nuts instead of T-bolts i.e. bolting coming down instead of being screwed on to the hole enlargement might be able to be avoided. That‘s me hoping…
I've just used generic SS rings + SS bolts with the heads ground down a bit (thinner) to fit in the FR channels
A little surgery with a grinder will make any ring bolt fit.
