The gremlin's are very real. Recently I'm getting tones from the dash without any lights or explanations. Very frustrating and aggravating. I wish INEOS could fix all this stuff.
A modern defender has 3x the electronics so take that off the list and from person experience I wouldn’t call it reliable. Really you are left with a Land Cruiser. A 70 series isn’t going to offer the long range comfort you likely want. Maybe a 300 series with some mods to make it more off road capable. Of course it’s also a very complex truck. Buy a professional grade scanner so you can diagnose any issues yourself.So my intended use is for overland trips/expeditions of up to a month or two, in Morocco/Africa, remote parts of Eastern Europe etc.
My wife and I need a vehicle that is comfortable to drive very long distances but also extremely dependable and capable off road.
I've owned several old Defenders before, and a couple of Land Cruisers, and am very capable mechanically. However, I'm not good with electrics and besides, any vehicle that either needs sophisticated diagnostic software and a laptop to fix, or worse, must be returned to a dealer to be fixed, is not something I'm willing to risk when stuck in the middle of the Sahara desert, or miles from anywhere in a remote area.
Interesting… i’ve read that people have had a lot of problems getting software updates for the earlier versions… Why on earth is that not possible?The MY22/23 had a load of software issues. Pretty much like all new vehicles. Many were ironed out with MY23.5. MY24 had a new software fork. MY26 has another fork I believe.
An MY24 onwards shouldn't have many software issues. All I find with my MY24 is if you park up, turn the engine off but don't open the doors, wait a short while, e.g. have a drink if you then fire up the engine again, it gives an amber ESC message. However, if you follow the same routine but open the door and close it again before firing back up, then there is no fault.
A lot of people don't realise that most orange messages are information messages. Ineos went a bit over the top with information messages.
Early builds often had their information cluster lit up like a Christmas tree. However, later builds rarely see anything come on that shouldn't.
Again, like any new vehicle from any car make, the first year or two will have issues they deal with. So, you need to consider when it was built when looking at those messages. e.g. sunroof leaks or footwell leaks on earlier ones that don't happen on more recent ones.
Americans seem to complain about the handling but Europeans less so. I have driven MY23 and MY24, and the latter was much better than the former and MY26 is better still. However, there is a jokey theory that each one comes off the factory line with its own personality. Also be wary that US builds and software are actually different to Europeans. Our US friends had some issues specific to them.
In very simple terms, the engine and body are solid. The software has a few quirks (but again, the newer the build, the better). There are a few niggles, most of which can be solved, but no more or less than any other car out there.
The earlier versions hit a development dead end due to new hardware. They fixed an awful lot in the earlier software, but you have to get it done at the dealer.Interesting… i’ve read that people have had a lot of problems getting software updates for the earlier versions… Why on earth is that not possible?
When you start digging into the nuts and bolts of the modern truck dilemma, you realize that the Grenadier is a good value prop. The two biggest issues are a closed off diagnostic system and sparse dealer support. Both of which I expect to be solved in time.
You might unfortunately set the record number of issues experienced by a single owner. I commend you for not giving up and dumping the vehicle long ago.I still genuinely like my Grenadier, but for balance I think it’s fair to share my ownership experience so far. These are the issues I’ve had, all fixed under warranty and in no particular order.
• Rear hub seal leak
• Diff input seal leaks
• Three power-steering-related recoveries (new gateway module + pump)
• Transfer box cables seized (4th recovery)
• EVAP filter clogged and replaced
• Prop shaft failure leading to further driveline/cooling repairs and eventually a new gearbox + more transfer box cables (5th recovery)
• Steering wheel module failure (no indicators, high beam, ESC, etc.)
• Winch control module failure
• Sway bar link hardware missing
• Auxiliary radiators repeatedly dropping from their mounts
• Failed windscreen washer
• Electric mirror motor failure
• Loose coolant pipes (self-fixed)
.Door seals coming unstuck
There are probably others I’ve forgotten.
.microphone for hands free is very poor.and no fix for that.
The latest one. Fuel sender/fuel level software fault. Fuel level indicator takes hours to register when full. Warning to say refuel soon even when full.
You expect the odd issue with a brand-new vehicle from a brand-new manufacturer. But the number and variety of faults have been far beyond what most people would tolerate.
I’m sharing this not in anger — I still enjoy the vehicle and see its potential — but it’s fair to say my patience has been well tested. I really hope future builds show more consistency, because the core product is something I genuinely like.
Build date 19/01/2023
Date of 1st registration 09/05/2023
No suspension lift pr steering modifications
