After market cabin filter option
4:12 AM
San Antonio
Hello, I finally found a replacement non-OEM aftermarket air filter off of Amazon. It fits perfectly. I’m going to post a picture of it. The big difference is it’s only 9 bucks.
Good find. 👍🏼
Got a link to the product on Amazon?
I found it.
Interesting what you get when you search using CF10729 (another part number used by Amazon), rather than MAF0729 (the Moselny part number).
sh1t, I've just purchased 2xOEM ones at about £55!
I couldn’t see the Moselny filter available in the U.K. the Amazon listing was USA so import and postage charges would be added
Where do y'all buy your IA/OEM parts at a healthy discount? I know my way around Toyota (e.g. partsouq), BMW (getbmwparts) and Porsche (Suncoast), but new to the IA scene. Thanks.
I’m watching the answers you get intently. OEM parts are expensive so i would like to find alternative pattern parts if possible or originals from a different supplier at a discount.
Let us know when you find it. Nothing obvious so far.
A while ago, I bought the Blue Print ADBP250065 HVAC filter because the dimensions seemed to fit and it only cost about 9,- Euros.
Unfortunately, it didn't fit. This wasn't because the filter element was too big, but rather because the plastic frame to which the filter material was attached. I wanted to use it for something else, but then I cut back the plastic frame with a knife so that the entire filter was only 25 mm high. Now it fits!!!
Unfortunately, this is only a temporary solution and I don't recommend it here. Therefore, I will continue to look for an affordable filter alternative that can be installed without any tampering.
what is the part number? How tight or loose of the fit w/ this filter?
I found it.
Ordered this from Amazon. Will test fit over the weekend.
Tom… how did it fit?
Pete - It appears to be the correct size when held up to the original filter, but I didn't install it. I was chasing an interior odor and suspected the cabin filter, however, my original filter was clean. This replacement is lacking the open cell foam around the perimeter I suspect helps make a good seal, and most importantly, it's missing a pull tab for removal. The factory filter has a pull tab that is the only way to pull it out without physically damaging it.
Before I need to replace it I'll find some foam to put on the perimeter and add a pull string.
Tom… Thanks, That’s very helpful. I will look for a roll of the soft perimeter foam and make some up. As far as a removal tab goes, after I replaced my factory original filter, I put in an after market replacement without a removal tab. I have an old dental pick that made it easy to grab the edge and remove the filter.
