5 Year Trip in a Grenadier Across the World towing a Patriot X3 Which We Live In.
Hi Matt if you set the screen brightness with the headlights on it is supposed to remember that setting independently of the setting when the headlights are off .
Hmmm.. that doesn’t happen our end. I’ll try again after the latest software update, maybe that’ll do the trick! 😊👍
Here you go Matt
Thanks for this 😊🙏
I just used normal large washers in mine and they have stayed put since.
Appreciate this but I think I’ll just use some larger washers as suggested below. I just never get around to it as there’s always stuff going on. 😂 Not a big deal. Makes me smile for some reason. Reminds me of a Land Rover 😂
Sir Jim's intention ;)
And I'll bet he loves this record
We’ll do this. 😊👍
Rather than a washer id diy it with a piece of 2mm thick plastic. About the size of the square opening area. Round the edges and cut it to shape for the opening. Door stop, some leftover packaging, almost anything flat will work. Then drill a hole offset of center for the screw to go through. I guarantee it will hold it better than a washer. The issue with a washer is that the hole is off center and there isn't a ton of room on one side, making only smallish washers feasible. I think a square piece like the folks from owl are using is a better design.
I used large penny washers, filed to shape. Haven’t fallen out since IMG_7222.jpegIMG_7218.jpegIMG_7221.jpegIMG_3482.jpeg
These things are 99 cents for 2, I think it's pretty cheap to get it you're already buying something else from owl. I think my local hardware store may be charging 30 cents for a washer so let's say I save 40 cents if I make them myself (this math only works if you buy something else that you need or you can pick it up, shipping is $4.99).
I particularly like that they make them from scap aluminum so they reduce waste.
My few cents (pun intended)
They could buy the scrap . very cheaply (I have plenty) from Australia , but the "For some reason, I am just a good golfer/athlete" golf cheat would add 50% tariff ;)
60,000km INEOS Grenadier Write Up After Driving it Mainly Off Road Around Europe and Asia For The Past Two Years
I wanted to share our experience to contribute to the community, but also because everyone on here and in the Facebook groups writing about their experiences has been incredibly helpful from our side. This is a new vehicle and so to see what’s going on around the world has been great! I hope people will find this useful. :)
We have an INEOS Grenadier Trialmaster Petrol with a few factory options. Everything else is pretty much standard. We’ve done close to 60,000km. About 75-80% off-road, towing a Patriot X3 Trailer
Conditions
  • Temps: -10C to +55C
  • Elevation: Sea level to 17300ft
  • Conditions (Snow / Ice / Gravel / Rock / Sand / Mud / Clay / Swamp / Water to wading limit / Asphalt - Everything!)
Countries
  • UK, France, Belgium, Netherlands, Germany, Denmark, Norway, Sweden, Poland, Slovakia, Hungary, Romania, Serbia, Bosnia, Montenegro, Albania, North Macedonia, Bulgaria, Turkey, Cyprus, Georgia, Russia, Kazakhstan, Uzbekistan, Tajikistan, Kyrgyzstan, China, Pakistan, India, Nepal
Service
  • 20000km in Sofia Bulgaria at INEOS Dealer
  • 40000km in Almaty, Kazakhstan (BMW Garage) as no INEOS dealers for a very long way after Sofia (if you’re in Asia)
  • Changed all brake pads at 47,000 km
  • Next service in Mongolia
  • 4 litres of extra oil required on top of normal servicing at 20k, 40k
Fuel - Based on 90L Tank
  • Max range on motorway / highway whilst towing a Patriot X3 Gen 1- 450km (with original AT tyres)
  • Min range on tough offroad whilst towing 230-240km
  • Fuel gauge is very conservative, becomes a little annoying after a while. Ours also stays around half full for a long time then drops off quickly.
  • Have to carry additional fuel regularly ~100L to do what we do. Initially we used Jerry cans, then Jerry cans plus fuel bladders (not recommended) and now we have a LRA 90L aux tank which we’re very happy with. The LRA tank plus our two Jerry cans brings us to 220L.
  • One major downside of the Grenadier is the range for the petrol version. Saying that, we can deal with it if it means it’s made of high-quality components, which it is. It's been extremely strong so far in everything we’ve put it through. We didn’t go for diesel because of DPF and AdBlue issues with where we’re going on our trip.
Issues
  • Air con - Issue we all have. Better on the warm side of things, keeping things cool, it struggles a lot. We have been in some pretty hot conditions but I don’t think that should be an excuse - Better after filter change but then reverts back to how it was. No leak confirmed. (Because of this we have the windows down a lot and end up having more dust on the inside than the outside sometimes!)
  • Trailer module - We had a PCB Failure (Trailer module replaced under warranty)
  • Didn’t start once in Uzbekistan - Tried multiple times. Very strange. Waited 20 mins and started fine. No issues since. Apparently a known gremlin with no fix
  • Sticky door locks after rain - Still waiting for full replacement. Will do in Mongolia
  • Dashboard warnings - Many 😂 After we disconnected the battery we had the Airbag warning on and were told it should still work fine. The parking sensors also stopped working. (No drama) Still have a service light and also brake warning and TSA but we know why the last two are, we’ll get them reset and resolved in Mongolia
  • Foot plates on half of the doors have come off
  • Various bolts came loose over time. The back door handle actually came off in my hand 😂 but it went back on fine. (Happened twice) All of the others went back fine too. This was mainly after a lot of corrugated trails.
  • Trailer stops charging at 84km/hr - we know why but it’s frustrating. The rear NATO is supposedly rear winch only. We’ve decided to rewire through an Anderson. It should be configured so that you can charge a trailer though. I’d say that it is a lot more common to tow a trailer than have a rear winch.
  • Back door mechanism broke - the metal bit at the bottom of the door snapped in half. We have a standard tyre on the back and that’s it. (We carry kids shoes in the compartment in the spare)
  • Back door lock of the smaller door got stuck several times and had to open from inside. It just needed cleaning but something to watch out for
  • Back door rubber stops - both fall off regularly
  • Paint on bottom sill of passenger door coming off
  • Some protective film coming off on roof rack
  • Rust on rock sliders - Now have Agile Offroad ones which are way better than the factory option. Lighter, more ground clearance and a footstep
  • Automatic light function and car play sometimes on the blink but seems to self correct over time and then revert back.
  • Very squeaky driver's window
  • Temperature display remains on the previous night temperature for hours into the next day (esp when it’s cold). Eg It'll say 0 when it's clearly much warmer (20+)
Events
  • Stone chip on windscreen from lorry in China. It’s holding for now.
  • Hit the rear bash plate, rear control arms and fuel tank guard several times, despite being as careful as we could
  • Factory rock sliders took a big hit (slipped off a big wet rock) and did what they’re supposed to, no other damage. (This was after the rust began on the sliders)
  • Steering wheel already starting to wear a bit in some places
Common Issues
  • Driver's footwell (RHD). Not an issue unless you do many days over 5hrs in row or if you haven’t driven the Grenadier for a while and go straight back into long journeys. I'm 6ft 1.
  • Steering - You get used to it. It’s not ideal in tight spaces (parking for example or having to turn around, especially with a trailer! 🙈)
  • Annoying warnings that constantly come up. Tyre pressure mainly, despite resetting
  • Didn’t start once - Tried multiple times. Very strange. Waited 20 mins and started fine. No issues since. Apparently a known gremlin with no fix..
  • Pin falls out of transfer case lever (Still no fix) Unacceptable in my eyes, if you don’t take preventative action, like we what we’ve done with the zip ties, you could be in a whole world of hurt, depending on the situation you’re in. This didn’t happen to us as I zip tied the minute I heard about it happening to the first Grenadier. Since then, I know it’s happened to quite a few.
  • Bit tricky to get diffs in and out and wading mode etc. Key to that from my perspective. When you go off road, put Off Road mode in straight away. Sounds obvious but saves hassle further down the line.
  • Lock diffs- Straightforward just do in order. Rear then front.
  • Unlock diffs - Easiest we’ve found is to take the centre diff out and then do a few full lock turns left and right and it all comes out every time. Then lock the centre diff again if you need it.
Key Preventative Things I’d Suggest Doing
  • Zip tie transfer case lever (Still no fix for the pin falling out)
  • Bowden cables (get them replaced by INEOS or get the Agile Off-road Shifter bracket solution or put pipe insulation and zip ties around so no rubbing. Thanks Dave (Logsplitter for the heads up on these in the early days)
  • Check all hoses/pipes/wiring in and around the engine bay and front light area - Lots of rubbing in various places. (Again, thanks, Dave for the heads up here too)
  • Get the additional radiator and transfer case oil cooler brackets fitted if you haven’t got it on your Grenadier. A few people have had issues. You have to retrofit if you have plastic bumpers, as they’re metal bumper parts.
  • Keep locks clean. You don’t want to not be able to open the rear door if you really need to and the only option is to unpack everything from the inside (Speaking from experience)
  • Batteries run down quite fast over a few days with minimal drain. Just using 12v and charging a few things so be aware, you may need to run the car every now and again to keep them at a good state. (We have dual battery system from factory)
  • Don’t drive fast with a petrol Trialmaster while towing, especially uphill, you’ll run out of fuel fast… 😂
What We Love
  • Most things to be honest. The way it has handled what we’ve put it through has been very impressive, despite all the very small things mentioned above. We’ve found that with 285/70/17 MT tyres and all the lockers, it’s unstoppable in some pretty challenging conditions. Testing is still underway.. 🙃
  • Build quality always impresses me
  • The ZF Gearbox and engine are great.
  • HDC is amazing
  • Off-road capability using just L and centre diff is very impressive! We use rear diff when required and front diff rarely but we have used it enough to justify it.
  • Toot horn is very useful in a number of situations - way less aggressive than the main horn
  • All the switches - Very well laid out and easy to understand and operate
  • Recaro Seats - Very good
  • All in all, as we all know, very well built and over-engineered, built for trips like we're doing.
Suggested Improvements for The Grenadier from our end
  • Rubber on ladder steps
  • Proper snorkel
  • Higher ground clearance
  • New air con system
  • Shorter bumper
  • Steering locks adjusted from factory to allow for a tighter radius
  • Smaller footplate for RHD cars even though I understand why they can’t with current versions
  • More USB C Ports
  • 240V Inverter as was originally planned
  • Warnings need to have an option to clear permanently, but have a recall option to check warning history and bring it back up if you’d like to (Can get annoying after a while)
  • Fuel gauge levels need correcting
  • Better way of connecting and powering trailer rather than turning off at 84km/hr (We now do ours through an Anderson plug)
  • Auto dimming on the infotainment screen at night
  • Illumination on ignition
  • Better AT tyres from the factory, they’re not great in the wet or mud
Modifications We’ve Carried Out
We like to keep it as standard as possible but these are all due to our experiences to date
  • REDARC Brake controller
  • 285/70/17 tyres (Currently using MT tyres and they’re a game changer in terms of capabilities of the vehicle. We're still deciding on what we’ll use for the rest of the trip. Aggressive AT tyre, RT tyre or stick with MT)
  • LRA 90L aux fuel tank with Edelbrock pump and uprated black OEM springs
  • Diff breathers (From Agile Offroad)
  • New Rocksliders (From Agile Offroad)
  • Full Underbody protection - Engine and centre skid plate / Fuel Tank / Rear Control arms skids / Diff covers / Diff skid plates (All from Agile Offroad)
  • Shifter Cable Support Bracket (Agile Offroad)
  • Reservoir cap seals (Agile Offroad)
  • Starlink Mini
Future
  • A slight lift, possibly. Needs to be proven in tough terrain over a long period of time due to the CV joint risk that’s been well documented. If anyone has any suggestions here, we’re open to them.
All in all, no major dramas! All the important things have held up which is why I bought the car in the first place - the way in which it has been designed and built. INEOS have done a very good job. We LOVE ours! Very happy with taking the plunge. A bold move perhaps, to drive around the world with your family pretty much straight off the forecourt, but I’ve done a lot of trips all over the world in vehicles way worse than this, so I figured it’d be fine. So far, so good. 👍😎 I hope this helps, especially the preventive stuff. We’ll do our best to answer any questions, keep everyone posted periodically and help wherever we can.
We’d also like to give a special shout-out to everyone at Denton’s in Skipton who have been there every time we have a question or concern. They’ve been great throughout. We’ve also received great support from Dragan at INEOS in Sofia, Charles at INEOS Kavango, Ariunbat and Matt at INEOS in Mongolia, Stu who runs the INEOS Forum and Dave (Logsplitter on the INEOS forum). We’d also like to thank everyone who has supported us through the challenging time we had with the fire in our trailer. We can’t thank you enough. It’s allowed us to continue this journey which means a lot, thank you. 🙏
Hi Matt,
I think we all in the forums are loving you and your family, your adventures, your stories and videos and adore your determination to live this adventurous life - most of us are not brave enough for this kind of experience. I have to admit that Leah is the better story teller and I love to listen to her in your professional videos. Just continue ...
Hi Matt,
You are not wrong when you say most of us are not brave enough, myself and the wife definitely fit into that category. This enables us to dream through the family adventures.
What i love the most is seeing the little children wander off and nobody takes any notice. Sadly nowadays in UK they don't go anywhere without a parental escort, unlike when I was young. I find it so sad that children aren't seen as safe to be able to just do what they want and learn the responsibilities to look after themselves.
I agree what a wonderful and informative education those children are getting and experiences that will last a lifetime. They’ll have the travel bug for sure
@globalgregors @Logsplitter and @Matt P are out there living the life the rest of us dream of. Getting to watch is a treat. Thank you all for sharing your journeys!
Unfortunately I still have to do some work. Next big travels in the Grenadier are next year although we are travelling a lot without the Grenadier this year. Shipping the Grenadier to New Zealand and the Cook Islands may be costly 😂
@Matt P -- On the Air Con, have you tried the "start-up" and "shut-down" procedure?
Basically, every time before you turn off the ignition, make sure all three air con dials are turned completely counterclockwise (i.e. fan off, full cold, face vents only). Don't restart it again until the computer has had time to go to sleep (3min 35 seconds from locking the doors for mine). When you restart, turn the ignition one step short of turning the engine and allow the computer to run through its start-up checks (you will end up with only 3 or 4 warning lights on the dash, unless you are in offroad mode). Once the warning lights are stabilized, turn-over the engine. Then you can start the air con. I don't use the auto function.
I find this procedure has 100% success rate on mine for "resetting" the AC when it starts it thing of only blowing hot air. If I remember to follow this when shutting down, it is about 95% successful in preventing a repeat.
Sometimes I'm in a hurry though and forget to shut down the AC before turning off the engine and about 30% of the time the problem will return.
I seem to recall you had some experience in the aviation industry, just think of this like your prestart and shutdown checklists.
Open house here for other Grenadier owners who adventure so far from home! But you’re ruining my idea of “Grenadier Swapping” around the world! 🤣
  • Well done
Reactions: CRH
Hi Matt,
Thanks for this Pat, we’ve concluded Leah’s definitely better at telling the story through YouTube, I’m better in the pub with a beer! 🍻
Totally agree although we’re always watching them or ensuring they’re in a safe space to do what they want to do. Once you’re out of Western Europe, everywhere is so family friendly and family orientated that everyone becomes part of the family and helps take on the responsibility. We’re very comfortable to let them do what they want to do and it’s a big reason we’re doing this trip so they could grow up like we did. We’re not naive though, someone is always keeping an eye on them just in case. We prefer big open places where they can roam as far as the eye can see, you do have to watch for glass unfortunately, it seems to be in a lot of places you wouldn’t expect. People drinking then smashing their bottles… 🤷‍♂️🤦‍♂️
Hopefully it’ll help form a solid foundation so they’re ready to take on the world with whatever it is they want to do..
