I am opposed to cutting down trees so I prefer the synthetic carbon neutral optionHate those things with a passion; think I'd prefer to take my chances with one of these
I totally understand the hesitancy for this type of oil change method.That seems indeed convincing.
But the (i.e. at least my) doubts do not question that one can get the oil out more or less completely. You demonstration did however much better than I expected.
You know that I am an old school mechanic and I am not very convinced from the vacuum method. And I still (yes, I'm sometimes a bit stubborn) asking myself, what you would get if the oil came out in a massive stream. If there is no oil left in the engine (which we've seen), how could these two drops flush out any potentially existing sticky residue?
So I still have some reservations when comes to engine screening, i.e.: examination of metal parts and chips which will, if there are some, accumulate in the residue. My feeling is that they can hardly be flushed out through the oil drain with no oil in the pan and will thus remain undetected.
There is a reason that airplane engines have (to my knowledge) to be drained traditionally by regulation.
Funny you should post that @Andy, Land Rover have been doing this for years. And if you’re unsure if an evacuation tube gets all the old oil out then wait until the end where I find out.
The disco4 LR4 oil change and filter change 20 minutes with zero mess.
I’m all for a vacuum tube to get the old oil out. I won’t even have to buy and new tools![]()
A leap of faith towards European engineering. You'll be fine. They have done a lot of testing.Ah well, time to change perception I suppose..
Just came across this one, if anyone is intersted
They are completely sealed and don't give off fumes like old batteries.Not much room in there for anything else is there. I suppose with the battery under the rear seat all the electrickery that goes with that will live there anyway.
I've always been a bit suss about having batteries in the cabin (I'm assuming they're AGM at least?) Ah well, time to change perception I suppose.
As long as the aux power cables go to places that make sense (no idea why I want 4 on the roof???) then it should be fine and dandy.
If it’s the same guy who was on rhe Overlander forum a hundred years ago, I recall he had a V8 Disco at the time I think.I noticed the bloke who posted this goes by the name of TempestV8.
I remember there was a large contributor on the Landcruiser 200 series forum going by the same handle. Looks like the Grenny has a large follower base.
No keep rowing, every "fact" needs fact checking.So I’ll keep my oar out until it’s confirmed when vehicles delivered.
