Well I tried
Exactly why I did’t order Safari’s. I figured the potential for issues on a new vehicle were high enough without guaranteeing one.
I liked the extra space, and was considering taking the glass frame parts off and replacing the glass with a AL sheet with radio mounts welded on, and putting ham up there. But, it turns out, its the first sunroof I've had that I actually like to use. So, I picked up the RHD left side A pillar cover to access the grab handle holes, and am going to fabricate a cross bar above the dash to mount radios/ipad mini to.
It's not a matter of time. Its just a few OZ of water sitting there. there's no stack pressure. Someone isn't doing their job and pissing on your leg.
Mine is proper tight and it still leaks
Tomorrow I'll post the solution my dealer did that seemed to fix the problem. PACNW gets it's share of rain. No issues post fix.
Mine will not leak unless parked on an uphill slope of approx 9⁰. Have you done that overnight in heavy rain without leaks?
My seals have been changed many times, are fixed in with black silicone. The glass shut has been made much tighter and it still seaps in between the glass and the seal at the back parts
